Coolant leak...D16Z6
Old May 9, 2004 | 07:56 AM
Infamous_Imports's Avatar
Default Coolant leak...D16Z6
I've got an anti-freeze leak on the backside of the motor and I need to pinpoint where exactly it is coming from. I don't have much knowledge on engine coolant systems, so I pulled out the helms manual. I took a look at it and checked out all the hoses that run behind the motor for your coolant. I rubbed a couple of hoses to see if they were a little wet, grimy and whatnot. Well it turned out that the one hose that was a little wet is the bypass hose that runs to your EACV from your connector pipe below it. Now what I need to know is:
-Is it possible to have a leak in/from this hose?
-What exactly is the function of the bypass hose?
-What else should I check/look for?
-Once it is fixed will the check engine light go off? Or will it need to be somehow reset?
Thank you
Old May 9, 2004 | 10:01 AM
Default Re: Coolant leak...D16Z6 (Infamous_Imports)
After I looked at it a bit more it might be the heater hose, what exactly is the function of this hose?
Old May 9, 2004 | 10:27 AM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports &raquo;</TD></TR><TR><TD CLASS="quote">After I looked at it a bit more it might be the heater hose, what exactly is the function of this hose?</TD></TR></TABLE>
gives your car heat.
Old May 9, 2004 | 10:35 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Sends coolant through your heater control valve, which opens and closes to allow hot coolant through your heater core inorder to have heat.
It's a very cheap part, and not to hard to replace. Just make sure your clamps are on good, and you might even want to buy adjustable screw-down type hose clamps.
Old May 9, 2004 | 12:01 PM
Would this heater hose leak cause the motor to overheat?
Old May 9, 2004 | 12:15 PM
Draco's Avatar
Default Re: (Infamous_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports &raquo;</TD></TR><TR><TD CLASS="quote">Would this heater hose leak cause the motor to overheat?</TD></TR></TABLE>
If you leaked enough coolant to where the engine heat no longer has anything to transfer to. But if you check your coolant every dayand keep it topped off, you'll be good until you replace the hose.
zdizzle
Mar 10, 2008 10:50 AM
creepy116
Aug 5, 2007 08:51 PM
yOnKiNaToR
Sep 20, 2006 10:46 AM
