how hard is it to fix a spun bearing?
I found a car i kinda want to buy, but it has a spun bearing on the 4th rod? (i think thats what he told me) .. how hard is this to fix, i never done this, and how much is an estimated cost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic »</TD></TR><TR><TD CLASS="quote"> it has a spun bearing on the 4th rod? (i think thats what he told me) .. how hard is this to fix, i never done this,</TD></TR></TABLE>
A machine shop can resize the rod if it's not beat up too bad. Otherwise it will need to be replaced. The crank journal will need to be checked out also.
Guest
Posts: n/a
If its minor then you can get the crank "cut" and run oversized bearings.
I don't suggest it, but thats just me I will never run a "cut" crank.
The crank is trash, and there is a slight chance the rod is too.
