P28 and GSR runner question.
Old May 8, 2004 | 10:33 PM
Aeka GSR's Avatar
New User
Default P28 and GSR runner question.
I understand that the p28 cannot control the secondaries. I am also told that the vacuum line must be blocked in order for the secondaries to remain open. I took a look at my diaphram and runners. I saw that a vacuum line was connected and that the diaphram had the lever fully extended, which I assume is full open. I started the car and let it idle for a vacuum. I noticed that the diaprham arm was still fully extended which meant that they were still wide open. Is this normal? I thought the line had to be disconnected in order for them to stay open? I have a stage2b hondata if that makes any difference.
Old May 8, 2004 | 11:19 PM
mmuller's Avatar
Mad Scientist
Default Re: P28 and GSR runner question. (Aeka GSR)
yeah, for them to stay open you have to disconnect the vaccum hose.
On the stock car , when you turn the car on the engine creates vaccum, the actuator should go up and close the iab's
Old May 9, 2004 | 07:25 AM
Aeka GSR's Avatar
New User
Default Re: P28 and GSR runner question. (mmuller)
is my acuator broken or something?
edit: just pulled off the vacuum line and felt no vacuum. Anyone have a vacuum schematic?
Modified by Aeka GSR at 9:43 AM 5/9/2004
Old May 9, 2004 | 08:54 AM
Aeka GSR's Avatar
New User
ok I got a diagram. Would I be correct in assuming that the vacuum tank is worthless with the p28? I could just remove it, right?
Old May 9, 2004 | 09:17 AM
Jim Truett's Avatar
Go to pgmfi.org and learn how to add IAB control to your P28.
Old May 9, 2004 | 09:50 AM
Aeka GSR's Avatar
New User
Default Re: P28 and GSR runner question. (Jim Truett)
im not worried about the runner control at the moment, the turbo seems to make up for it, heh.
tgkaotic
Oct 3, 2012 09:21 PM
Maldito X
Jun 16, 2010 05:50 AM
b16a4
Oct 31, 2007 03:44 AM
Hoodwinked
Feb 11, 2005 03:50 PM
