Sensor trouble...
Old May 8, 2004 | 08:05 PM
stew18564's Avatar
Default Sensor trouble...
i got a 96 b18c1, and it idles alil weird...i believe its the AIC sensor, or IAC sensor, whatever the hell its called..do any of you know where i can buy one of these sensors? i tried searching on yahoo for them, but couldnt find any place..if you could help it would be appreciated
stew
Old May 8, 2004 | 08:23 PM
Ivan's Avatar
senior gold member
Default Re: Sensor trouble... (stew18564)
get it from the dealer or a junkyard. Something I did was to take mine off and cleaned it. It still idled all messed up so I hit it a few times with a screwdriver and fixed it
Old May 8, 2004 | 08:25 PM
stew18564's Avatar
could you tell me how to get the sensor off? im sort of new to the honda stuff, and not educated bout these sensors here..if you could explain it to me it would be greatly appreciated...
Old May 8, 2004 | 08:28 PM
Ivan's Avatar
senior gold member
Default Re: (stew18564)
theres 2 bolts to it, 12mm and 2 hoses connexted to it.. Do you know where its located? Not sure on the b18c1 since I have only worked on b16 headed motors but it should be behind the intake manifold.
Old May 9, 2004 | 05:02 AM
stew18564's Avatar
alright, i think i might be able to figure this out then...doesnt seem to difficult...thanks for the help to you..
stew
Old May 9, 2004 | 06:14 AM
Ej1_coupe's Avatar
You want to look at the thing labeled eacv in this pic.
Dc2phil
Sep 17, 2012 01:34 PM
subliminaltrance
May 16, 2009 10:35 AM
