CVCC help!
Old May 8, 2004 | 06:46 PM
turbo_ef9's Avatar
Default CVCC help!
okay guys.. well i pulled off my dizzy and i wasn't expecting it to throw off my timing.. anyone know which way the rotor is pointing when tdc? also.. i just bought a cluster with an rpm gauge for my cvcc and i dont know where the cable runs to.. does anyone have a cvcc manual and help me out? HELP!!!
Old May 8, 2004 | 07:30 PM
fizzbob7's Avatar
Default Re: CVCC help! (eli_vang)
can't you just follow the number 1 plug wire to that point on the cap and put it there....fine tune it later?
Old May 8, 2004 | 08:04 PM
turbo_ef9's Avatar
Default Re: CVCC help! (fizzbob7)
anyone else?
Old May 8, 2004 | 08:50 PM
Aquafina's Avatar
Might be some help here
http://www.1stgencivic.com/index2.html
H-T needs a First gen forum.
May not be a lot of members now with them, but if H-T got a 1st gen forum, owners would flock here.
Old May 8, 2004 | 08:56 PM
Ejay Six's Avatar
Default Re: CVCC help! (Aquafina)
EG+ Civic / Del Sol
EG/EK+ Civics
You sir are in the wrong place
Old May 8, 2004 | 09:03 PM
Aquafina's Avatar
Default Re: CVCC help! (Ejay Six)
Hey ***, there is no forum for old Civics.
Old May 8, 2004 | 09:04 PM
Ejay Six's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Hey ***, there is no forum for old Civics.</TD></TR></TABLE>
Yes I know this. Which is why I wonder, he posted in here.
Would he assume any of us knew anything about CVCC's? Huh, I for one, dont.
Old May 8, 2004 | 09:22 PM
fizzbob7's Avatar
uhh...doesn't common sense apply here....if it has a cam, a distributor, wires and a rotor, then it would have to line up just like most do.....the number one wire (closest to the cam gear side) would lead you to the number one place on the cap where the metal part of the rotor (contact) would want to be........
now if for some reasons they aren't like that, then completely disregard EVERYTHING i've typed like an idiot........i completely can't remember the one and only engine i've seen like that lol
good luck
Old May 9, 2004 | 07:45 AM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejay Six &raquo;</TD></TR><TR><TD CLASS="quote">EG+ Civic / Del Sol
EG/EK+ Civics
You sir are in the wrong place</TD></TR></TABLE>
quit being such a dick.. i should go tell my mod friends and have them dock ur percentage... shut up.. anyawys.. i lined up the metal part of the dizzy to number plug wire while the cam gear showed tdc.. it will kinda start, but then starts like ****.. any thoughts?
Old May 9, 2004 | 02:39 PM
fizzbob7's Avatar
i'm sure the same logic applies, but you can always pull the number one spark plug to make sure it's at BTDC by putting an extension or something in the hole and manually turning the motor.....to make sure all the marks are right (if there are any) because i've had cars that used plastic shrouds with pointers that got broken.........but if that looks to be about right still (right before the piston is all the way up and the rotor is on the #1 wire) then i don't know....may not be related to the timing....maybe you can bump the distributor around toward the advanced side to get it a bit more "in time" too....does it drag a bit then start, or what....could mean the timing needs to be advanced
florida
Aug 26, 2006 08:03 AM
Mr Lotion
32
Nov 20, 2003 04:59 AM
VTECTIME
Dec 26, 2002 03:20 AM
RR98DX
Aug 6, 2002 04:54 AM
DragII
15
Oct 12, 2001 02:29 PM
