4G auto tranny quest..
i have a problem with my auto tranny... when i put it in d4 it doesnt move untill the rpm is at 3000... then it moves a lil.. have any one else encounter this type of problem?? any advice is appreciated.. thanks
From: gravity rides everything...everything will fall, se GA/ne FL
you have a turbo automatic? if it doesn't move till 3k that is ok i guess. the factory stall is about 2500-3000 rpm (hydro lock-up). unless it's different than it used to shift.
well.. its the auto tranny.. when i put it to d4 it doesnt move at all.. when i put to one.. it does the same... only thing it does is when i put it 2 and it moves then it shifts when when i put to d3 or d4.. but i cant get the 1st gear to lock anymore.. anyone had any problems with that b4??
Maestro Kull
Transmission & Drivetrain
Oct 19, 2015 07:38 PM
blackriceman
Dec 23, 2005 03:14 PM
ITR1071
Sep 19, 2002 04:12 PM
