motor problem: broken sparkplug
Old May 8, 2004 | 11:39 AM
magic hat #9's Avatar
Default motor problem: broken sparkplug
my poor R motor consistently breaks/melts the electrode off the sparkplug in cylinder #3
this is a stock R motor with a toda header, smsp cat, and the milk jug removed from the stock intake. the other plugs are white (lean?), but don't have any other issues. the fuel filter is new and i moved the injectors around (assuming clogged injector), but the problem remains with cylinder #3.
the motor's compression is fine, cylinder #3 is probably the best of the bunch. is it possible the piston could contact the sparkplug, but not damage the valves?
i do the valve adjustments myself and the problem occurred before the adjustment and remains afterwards. the distributor timing was checked and is at stock 16deg btdc, but i plan to get it rechecked.
what haven't i thought of? what could cause this problem?
i've heard that a header can cause a motor to run lean and cylinder #3 already is the "hottest" one, but i've never heard of anyone else having this problem.
Old May 8, 2004 | 11:44 AM
Finland's Avatar
take it to someone that has a wideband to see if it is running lean. Could be that the wiring is bad, or if you are running aftermarket injectors, the wiring could be backwards on that injector harness...or the injector driver in the ECU is bad for #3, you could check that by plugging in another ECU (if you know someone that has one..)
Old May 8, 2004 | 12:12 PM
Tweakmeister's Avatar
Default Re: motor problem: broken sparkplug (magic hat #9)
intake manifold clogged?
Old May 8, 2004 | 12:13 PM
also try resetting ecu...although it's probably something more major
Old May 8, 2004 | 12:55 PM
kkim's Avatar
have you tried a one step colder plug?
Old May 8, 2004 | 01:08 PM
00MRSi's Avatar
Default Re: (boost psycho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost psycho &raquo;</TD></TR><TR><TD CLASS="quote">take it to someone that has a wideband to see if it is running lean. Could be that the wiring is bad, or if you are running aftermarket injectors, the wiring could be backwards on that injector harness...or the injector driver in the ECU is bad for #3, you could check that by plugging in another ECU (if you know someone that has one..)</TD></TR></TABLE>
His injectors are stock. Like already said, you should get your A/F ratio checked. Maybe a colder step spark plug will help also.. Just ideas.. Good luck..
Old May 9, 2004 | 10:16 AM
Default Re: (00MRSi)
i hope to take it to a dyno shop this week to get tested with a wide-band and get the distributor timing checked. i also have a vafc that i'll get tuned; it's not currently plugged onto the ecu.
i'm going to look into running plugs that are 1 step colder.
how would a lean/hot motor be indicative of a clogged intake manifold? wouldn't lack of o2 cause it to run rich? i haven't pulled off the intake manifold, but the throttle body is spotless; i would assume that for something to get into the intake manifold it would have to leave residue on the throttle body.
Old May 9, 2004 | 12:30 PM
b19coupe's Avatar
My suggestion would be to get it tuned with a wideband, which you appear to be planning. Sounds like the motor is running extremely lean.
Old May 9, 2004 | 01:05 PM
vtec.dc2's Avatar
what kind of spark plug and how many miles?
Old May 9, 2004 | 01:34 PM
Default Re: motor problem: broken sparkplug (vtec.dc2)
i have moved the injectors around and the problem remains with cylinder #3.
the car has oem injectors, wires, & sparkplugs; 62k miles on the odo.
could the spark wires for cylinder #3 be damaged causing poor spark? i guess it doesn't explain leaness.
Old May 9, 2004 | 01:46 PM
vtec.dc2's Avatar
i guess it woulnd't hurt to replace all simple things.. so replace wires if they have 62K miles on them, replace your dist. rotor if you haven't yet for these 62k miles. then see if you still have that problem. i'm not sure about piston/valve damage from this.
and how many miles do your sparks last until this happens? usual boltons without tuning will make the car run leaner, but i wouldn't expect all this to happen.
Old May 9, 2004 | 05:10 PM
stumpyf4's Avatar
Sounds like a lazy primary O2 sensor. Pull it out, bench test it and replace if necessary.
Old May 9, 2004 | 05:31 PM
Default Re: motor problem: broken sparkplug (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a lazy primary O2 sensor. Pull it out, bench test it and replace if necessary. </TD></TR></TABLE>
could it cause this? good idea, i'll just buy a new one in hope that it fixes it. do new o2 sensors need to be spliced/soldered onto the existing wire?
the cap/rotor were just replaced. the plug seems to last around 5k miles. once the plug breaks, there is an occassional intermittent stutter at idle but it's seems to run fine at partial throttle/wot.
one would wonder where the 3 previous electrodes have gone, but the compression checks out fine. i believe it slowly melts away and the metal bits are ejected through the exhaust valves. i poked a magnetic wand through the spark plug well and rubbed it around on the piston and didn't pick up any metal.
Old May 9, 2004 | 05:38 PM
vtec.dc2's Avatar
bad O2 sensor can cause both lean and rich condition, only other thing i can think of is to check the gap, and replace spark plug wires if you suspect one of them isn't good.
Old May 9, 2004 | 05:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">bad O2 sensor can cause both lean and rich condition, only other thing i can think of is to check the gap, and replace spark plug wires if you suspect one of them isn't good.</TD></TR></TABLE>
gap on oem plugs is set at 1.1mm. i'm going to chase down the distributor timing and replace the o2 sensor asap.
Old May 10, 2004 | 07:27 AM
honda guru rodney thinks i might have a faulty fuel pressure regulator. he felt it was unlikely the o2 sensor because the car has not (but should have) thrown a code.
Old May 10, 2004 | 07:29 AM
MattD@Stoptech's Avatar
Get a fuel pressure gauge?
Old May 10, 2004 | 07:39 AM
Default Re: motor problem: broken sparkplug (El Pollo Diablo)
i'm going to the jeimports dyno in maryland on wednesday morning. they will check the fuel pressure (and they have an aem fuel regulator in stock), dyno tune the vafc, and check the distributor timing. i've got my fingers crossed!
Old May 10, 2004 | 07:58 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to the jeimports dyno in maryland on wednesday morning. they will check the fuel pressure (and they have an aem fuel regulator in stock), dyno tune the vafc, and check the distributor timing. i've got my fingers crossed!</TD></TR></TABLE>
Sounds like a good plan.
I was going to suggest an FPR for use with the VAFC (FPR to up the pressure and VAFC to trim it out where needed).
At least you noticed this before it ended up with a burnt piston or worse.
P.S. Where's J E Imports located?
I'll be on the road Weds making my way north and ...
Old May 10, 2004 | 08:23 AM
Default Re: motor problem: broken sparkplug (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
I'll be on the road Weds making my way north and ...</TD></TR></TABLE>
je is in parkton maryland, i bit north of baltimore. i'll be there from 10-12ish - come on by!
Old May 10, 2004 | 08:25 AM
je is in parkton maryland, i bit north of baltimore. i'll be there from 10-12ish - come on by!</TD></TR></TABLE>
http://www.jeimportperformance.com/interface.html
Old May 10, 2004 | 08:31 AM
ZygSpeed's Avatar
Thanks guys.
Old May 11, 2004 | 08:07 PM
stumpyf4's Avatar
The primary O2 sensor is only feed back to the ECU on the lean/rich mixture. If it detects a lean condition and asks for a enrichment and doesn't see any enrichment it will set a trouble code for too lean. My feeling is since you're not seeing a MIL light it's the O2 sensor being lazy... not reading correctly. The sensor voltage is not outside parameters (if outside parameters it will set a MIL light for O2 sensor) just not reading the rich/lean condition as it should. Just my $0.02, good luck with the diagonis.
Old May 11, 2004 | 08:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">The primary O2 sensor is only feed back to the ECU on the lean/rich mixture. If it detects a lean condition and asks for a enrichment and doesn't see any enrichment it will set a trouble code for too lean. My feeling is since you're not seeing a MIL light it's the O2 sensor being lazy... not reading correctly. The sensor voltage is not outside parameters (if outside parameters it will set a MIL light for O2 sensor) just not reading the rich/lean condition as it should. Just my $0.02, good luck with the diagonis.</TD></TR></TABLE>
doesn't really make sense the o2 could be so "lazy" that the motor is running lean enough to melt spark plugs but doesn't pop a cel. i'm going to the dyno shop tomorrow, they are going to check the fuel pressure and perhaps we'll narrow this down to a busted fuel pump or a broken fuel pressure riser.
Old May 11, 2004 | 08:12 PM
BlueR's Avatar
good luck tomorrow aaron
