For those who run street tires at the track, psi?
Old May 8, 2004 | 06:12 AM
HNDAPWR's Avatar
Default For those who run street tires at the track, psi?
When I goto the track, I usually run street tires because I would like to know my real world/street driven times. I run anywhere from 18 psi to 25 psi depending on track conditions, temp, etc. Plus I hate swapping tires and stuff at the track. I did pick up a set of drag radials, just waiting for a deal on some 15's to throw them on.
So what do you guys run as far as tire/psi combo?
Also, anyone from the Michigan area going to Milan next weekend for Imports vs. Domestics? If so, see ya there.(Hopefully in the CRX)
Old May 8, 2004 | 06:50 AM
red cx's Avatar
Default Re: For those who run street tires at the track, psi? (HNDAPWR)
I run any where between 10-15 psi on my 225/50/15 bfg's.
Old May 8, 2004 | 02:03 PM
94gsr4dr's Avatar
Default Re: For those who run street tires at the track, psi? (red cx)
i run around 20-22 in my azenis when i use them
Old May 8, 2004 | 02:16 PM
ringgold's Avatar
Default Re: For those who run street tires at the track, psi? (94gsr4dr)
What kind of times and pressure are people running with Kumho Ecsta's 195/50/15?
I know they are not the best tires in the world but I managed to pull 2.1 60' with these tires at about 26psi. Just wnated to know what others ran with them
Old May 8, 2004 | 02:38 PM
blackboosted2's Avatar
21Psi in Yokohama YK-420 all seasons, 2.1 60'
94 Si B18c1
14.2@97.7
Old May 8, 2004 | 04:42 PM
james111's Avatar
Default Re: (blackboosted2)
if there bfg drag radial , we tested many pressures and found 12psi bas best,rwd best 1.3 60ft /fwd best 1.7 60ft .
now remember drag radials work better with less tread,the bfs was ran bald and gripped much better this way.was able to hold many 10 second passes.
regards
james
Old May 8, 2004 | 11:03 PM
.M.'s Avatar
.M.
Default Re: (james111)
how can u tell what psi ur running? use a tire pressure gauge?
Old May 9, 2004 | 07:33 AM
FerioVtec94's Avatar
Default Re: (JH4DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4 &raquo;</TD></TR><TR><TD CLASS="quote">how can u tell what psi ur running? use a tire pressure gauge?</TD></TR></TABLE>
uh yes
Old May 9, 2004 | 07:45 AM
HondaAccordSiR's Avatar
Default Re: (FerioVtec94)
I made my virgin run on friday, ran 22 psi on 215/45/17. I was just listening to my friend, but was very unsure if this was anywhere good for a tire that big.
Specially since he runs mustangs with 15's and monster slicks.
GreenMachineRex
Mar 16, 2005 06:02 PM
dc2Rgirl
14
May 20, 2004 11:49 AM
cliff666
Nov 3, 2003 12:12 PM
raene
Oct 2, 2002 05:40 AM
