Y8 into 92 CX
Old May 8, 2004 | 02:27 AM
Tw1n Turb0 Z's Avatar
Default Y8 into 92 CX
OK so the other day I am reading on my local forums and someone posts up this 92 CX with a full Y8 swap and some other goodies, asking 900 dollars
I call the guy go over there and ended up buying it but it does have some quirks I'd like to fix
I tried searching but havent found much info as far as swapping full Y8's into an EG but I know they used the stock CX wiring harness, so therefore a few sensors arent hooked up and its causing:
1. Idle is bouncing up and down while engine is cold
2. VTEC isnt even wired up (doesnt help they are running stock P05)
3. CEL on (I havent had time to check codes-maybe sunday)
4. Car wont rev past like 4500 or so (Cant tell, the car has stock CX cluster w/out tach)
I should be able to fix everything but I need to know if I can use a Z6 harness and swap that out with the CX harness or if I have to get a Y8 harness
Any other things you guys can recommend I would appreciate
Old May 8, 2004 | 03:52 AM
Tad's Avatar
Tad
hrmm dont know much about this,
but i know the y8 is obdII and the cx is obdI
so maybe they didnt convert it?
Old May 8, 2004 | 10:17 AM
hYbRiD EeEkAy's Avatar
Default Re: Y8 into 92 CX (Tw1n Turb0 Z)
the Y8 has a 4 wire o2 sensor while the cx has a one wire, youll need an obd1 p28 to run the motor correctly. convert the motor to obd1 (dizzy, alternator, injectors). a few of the sensors wont need to be connected while running obd1. the CEL's youre throwing are probly the vtec solenoid and o2 sensor. i did this swap a few months ago into my 93 cx and it runs awesome. i belive that all 92 hatches came prewired for vtec n e ways.
Old May 8, 2004 | 01:11 PM
Default Re: Y8 into 92 CX (KwikEG)
Did you use a different wiring harnes or did you use the CX wiring harness?
Old May 8, 2004 | 01:53 PM
Also
Any reason why I need to change the alternator and stuff like that?
The car is not having any problems running those items, or will the only problems I have be a CEL?
Old May 8, 2004 | 03:09 PM
you need to change those items if youre going to convert the motor to obd1. i used the stock cx harness because money was short at the time.
Old May 8, 2004 | 03:28 PM
s2000june's Avatar
i got a y8 in my vx
but the vx is vtec economy i used the stock harness. u need to get a p28 ecu 92-95 ex or si civics. get 1 of them and im not sure about your harness since a cx isnt vtec. u might just have to rewire stuff. when i did my swap i got all my info from d-series.org they seem to know alot more when it comes to sohc swaps . like they told my everything exactly what to swap and switch and what i had to convert. check it out.. theyll know..
Old May 8, 2004 | 04:08 PM
GSR-Civic's Avatar
instead of a y8.. you should of gone with a z6 with y8 tranny and manifold
Old May 8, 2004 | 04:22 PM
ABK's Avatar
ABK
Default Re: (GSR-Civic)
you can use your stock wiring harness, all you need to add is 4 wire 02 sensor, and two wires for vtec, really easy. Search you will find how to. Also since your car runs like ****, what usually fixes it is switching map and TPS sensor plugs, after that there are 2 plugs on the back of intake matifold that are the same too. First pull your codes and tell us.
Old May 9, 2004 | 03:22 AM
Re-read the initial post
I purchased the car with a full Y8 swap
Old May 9, 2004 | 01:23 PM
Default Re: (Tw1n Turb0 Z)
Pulled the codes today and I got:
Code 10-Intake Air Temp
Code 14-IAC
I also reset the ecu and installed the EX cluster and I am no longer getting the really low rev limiter, now I am just getting the stock CX rev limiter of like 6200 or something
Old May 9, 2004 | 02:09 PM
s2000june's Avatar
replace the iac sensor.
and your throwing a 10 because i dont think the Y8's have that sensor on the manifold. so yours is prolly just sitting there unpluged. im using a z6 mani so it has all sensors that my harness has.
Old May 9, 2004 | 06:07 PM
ABK's Avatar
ABK
Default Re: (civicrida3)
Those two sensors use exactly the same plugs (don't replace everything), just switch up the plugs it will get rid of CEL (two dark grey plugs on the back of intake matifold). Then when you put on p28 ECU you will need to wire up vtec and 4wire 02 sensor.
Old May 9, 2004 | 06:12 PM
DC2EGHB's Avatar
Default Re: (ABK)
If your car is a '92 its already prewired for VTEC to the shock tower.
Old May 9, 2004 | 11:16 PM
Default Re: (DC2EGHB)
Yes it is a 92
Old May 9, 2004 | 11:21 PM
tominos's Avatar
sounds like a deal of a lifetime
Old May 10, 2004 | 12:24 AM
Default Re: (tominos)
I'll agree
For as crappy as it looks right now it is a heck of a deal
BTW
I found these two plugs chilling earlier. I take it one is to the old alternator, but what is the other one for?
Old May 10, 2004 | 12:25 AM
I also need to clear this up
I am reading several conflicting posts about what 02 sensor I need
The car came with an aftermarket header with a 1 wire 02 sensor, do I need the 4 wire?
Old May 10, 2004 | 12:39 AM
Here are some pics of the front of the car
I did all the work today
Pulled the headlight, fender, broken corner, and hood
Fixed the headlight and some other crap, waiting on straigtening the body till I get a fender (anyone have one?)
Old May 10, 2004 | 04:29 AM
civicmatt's Avatar
One of those two "mystery" plugs could be for the intake air temp. sensor. The cx has it in the drivers side of the intake manifold. The y8 has it in the intake arm before the throttle body.
Old May 10, 2004 | 05:58 AM
ABK's Avatar
ABK
Default Re: (civicmatt)
Ok the white one should plug into the the white plug that's supposed to built in the intake matifold (look around for it on z6 it's on the drivers side towards the firewall). Also the plug that's laying around should hook up to this thing that has a cap over it, and has one house going from intake matifold (vacume) and the second to the charcoal canister (You might have to get that and tap into the intake matifold)
BTW your car doesn't look like CX since it got AC and all.
Old May 10, 2004 | 10:38 AM
Default Re: (ABK)
Well I wonder what model it could be then because I had a 94 CX one time and it didnt come with a tach, ,and I own a 93 DX hatch right now and it came with a tach. This one didnt come stock with a tach
I also have a friend with a CX who's doesnt have AC
Interested huh?
Old May 10, 2004 | 10:39 AM
Any word on whether or not I need a 1 wire or 4 wire O2?
Old May 10, 2004 | 10:49 AM
Hatchd's Avatar
I believe you need a 4 wire.
And AC came as an option on CX's. I've got a 93 and it has AC. They are just hard to find with ac.
Old May 10, 2004 | 01:40 PM
Default Re: (JapTendencies)
Update
I am not throwing any O2 codes, but I'll still go ahead and probably buy the 4 wire. I picked up the P28 ecu today, and the guy had an EX/Si harness just sitting there so i bought it for 15 bucks!
I think instead of doing some ghetto wiring I should just swap out the wiring harnesses? What do you guys think?
