del sol with front conversion
Old May 7, 2004 | 10:14 PM
air_mikey's Avatar
Default del sol with front conversion
i am interested in doing a front conversion and i am wondering if it would just bolt rite up if i got the civic rad support, fenders, hood, front, and headlights. the front would be the 92-95 civics. if any of you know if it is a straight bolt on thatn i would appreciate the help. thanks
mikey
Old May 7, 2004 | 10:25 PM
Built Beast's Avatar
Default Re: del sol with front conversion (air_mikey)
Rule number 1
1. Please do a search on your question BEFORE you post a topic.
Please try searching numerous key words under "recent" and "archived" topics in this forum and in the Hybrid Forum, or any other forum that applies to your topic at hand.
this topic is covered atleast once a week...
EDIT: here are some quick links.
https://honda-tech.com/zerothread?id=639285
https://honda-tech.com/zerothread?id=799918
Search Del Sol Front End, under archived....and you will get a lot of hits.
Old May 7, 2004 | 11:39 PM
all*motor*d16z6's Avatar
it can be done pretty easyly IM me if you want instructions i just don't feel like typing them right now
Old May 8, 2004 | 05:38 AM
air_mikey's Avatar
Default Re: del sol with front conversion (all*motor*d16z6)
do you have msn cuz i IM is disabled for me rite now.
Old May 8, 2004 | 08:32 AM
AIM eh693 no msn sorry
Old May 8, 2004 | 08:39 AM
I'll just write up a quick one on here
First take all the old parts off the car (hood,fenders,bumper,headlights,rad suport) then put the hood off the civic on the del sol all strait and everything. Then atach the headlights to the rad suport and have someone line them up with the hood while you weld the new suport on. After that is done you need to cut in half the del sol fenders about 6" back from the front then put them on the car now take you civic fenders and cut them about 7" back so you have a overlap line up the two halfs with the rest of the front end and then weld them together now you need to do a lot of smoothing with a grinder (don't heat up the fenders too much they WILL warp) and use some body filler. Once that is done put on the front bumper and get that bitch painted
Old May 8, 2004 | 09:50 AM
air_mikey's Avatar
tite! thanks a lot man.
Old May 9, 2004 | 08:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by air_mikey &raquo;</TD></TR><TR><TD CLASS="quote">tite! thanks a lot man. </TD></TR></TABLE>
no problem but next time search it has been covered a lot
milano_vtec
15
Mar 31, 2013 09:14 PM
jasongilholme
May 9, 2006 06:22 AM
redsol1080
Mar 5, 2005 07:35 PM
ismkv8s
Feb 19, 2005 08:21 AM
hukrice
Oct 16, 2002 08:13 PM
