another exhaust question...?
Old May 7, 2004 | 08:55 PM
al3e's Avatar
Default another exhaust question...?
I got my header, and catback piping.. i just need a cat or res, wondering if i should get a cat? or a res? i am wondering if i will be able to pass smog with a cat... my header is cutsom made so...doubt it... so should i just go and buy a cheapy "high flow cat" on ebay?
Old May 7, 2004 | 09:47 PM
HyBriDcxR's Avatar
Default Re: another exhaust question...? (al3e)
I passed emission with only a high flow cat. But i also had to add alcohol to help burn cleaner cause i couldn't pass the idle portion. A cat would of probably helped.
Old May 7, 2004 | 09:53 PM
94_HATCH's Avatar
I would recommend a cat for the test. you can always have it taken off after your test if you dont want it for performance reasons.
Old May 7, 2004 | 10:36 PM
slammed00si's Avatar
Default Re: another exhaust question...? (94_HATCH)
it would depend on where you live. i passed the smog part here in houston with no cat. but obd2 they just hook up and look for codes. so if they actualy sniff the exhaust you would want a high flow cat because you will fail otherwise. if they hook up to your comp get a test pipe(but you will sound like *** and stink very badly) or cat (sound better and wont stink like ***).
Old May 7, 2004 | 10:47 PM
Built Beast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend a cat for the test. you can always have it taken off after your test if you dont want it for performance reasons.</TD></TR></TABLE>
agreed...
srm238
Jan 13, 2010 03:49 PM
Extreez
Jun 29, 2007 06:11 PM
hatch_
Jun 26, 2007 06:05 PM
boosted94teggy
Oct 21, 2005 10:47 PM
bob barker
17
Mar 6, 2004 04:12 AM
