AEM Cam Gears stripping - need info
Old May 7, 2004 | 06:38 PM
Louie_EM1
Guest
Posts: n/a
Default AEM Cam Gears stripping - need info
Hi, and off the bat two things:
1) I'm not here to listen to how much AEM gears suck.
2) And I did search.
I am going in for a tune soon. I check the allen bolts everytime I drive because they're pretty round due to past adjustments. Now I want to replace them.
Anyone know where I can find these?
Anyone know the dimmensions?
If I contact AEM they're probably charge me for the same ones that will strip later. - Rather take a chance on another set.
Excuse the pic (notice the allen bolts)
Thanks
Old May 7, 2004 | 06:40 PM
Archidictus's Avatar
Unceasing Measure
I'm sure you could replace them with any number of fasteners from any number of hardware stores in your area. I highly suggest getting star-head or hex-head bolts of the same thread pitch and pattern if you're in the habit of constantly adjusting them.
Old May 7, 2004 | 06:50 PM
EG2 SiR's Avatar
Default Re: (Archidictus)
make sure to get an "automotive grade" for strength.
Old May 7, 2004 | 06:56 PM
Louie_EM1
Guest
Posts: n/a
Default Re: (EG2 SiR)
Ok cool.
But if anyone has dimensions, that will help me a lot.
Honestly don't know how to begin looking.
It might be so bad I might have to heat a wrench to the bolt to take it off.
Old May 7, 2004 | 06:58 PM
jaxle's Avatar
i tihnk the strip so easily because the gear itself is made out of aluminum. if you put steel ones in and overtighten then you will strip the threads in the gear. torque them at what they say in the manual (i think 12ft/lbs but that was for a different cam gear and even then i might be remembering wrong)
Old May 7, 2004 | 07:04 PM
EG2 SiR's Avatar
Default Re: (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Ok cool.
It might be so bad I might have to heat a wrench to the bolt to take it off. </TD></TR></TABLE>
I have a great place near my house called "King Bolt" I take them a bolt and say "I need one of these" they disappear for a sec, and come back with the same bolt... Maybe there is a bolt company near your place?
Old May 7, 2004 | 07:18 PM
bustah49's Avatar
Default Re: AEM Cam Gears stripping - need info (Louie_EM1)
you have the answer already
Old May 10, 2004 | 12:41 PM
Louie_EM1
Guest
Posts: n/a
I NEED DIMENSIONS PEOPLE!!!!!!!
Im gonna go to Napa
I called AEM they said they will NOT sell me any and not give me any. WTF kind of company says this?!
Old May 10, 2004 | 12:43 PM
jolt-tsp's Avatar
Lemme know what you find out, I need to replace mine as well.
Old May 10, 2004 | 01:01 PM
92RED Hatch's Avatar
Default Re: AEM Cam Gears stripping - need info (jolt-tsp)
seems like they are nice people huh... you should have asked them the dimension at least while you talked to them....you would have answered you question...
AFAccord
Jul 14, 2008 01:44 PM
urnotfast
Sep 19, 2007 10:39 PM
00ITR#1278
Apr 5, 2005 10:34 AM
Louie_EM1
May 10, 2004 01:59 PM
JeffNA
Feb 27, 2002 08:05 AM
