Should I use Denso Iridium or NGK platinum.....for my ITR.
Old May 7, 2004 | 06:27 PM
ITRFetish2000
Guest
Posts: n/a
Default Should I use Denso Iridium or NGK platinum.....for my ITR.
Same question, time to change the old spark plugs.
Old May 7, 2004 | 07:02 PM
SLCTyper's Avatar
Default Re: Should I use Denso Iridium or NGK platinum.....for my ITR. (ITRRTI)
Unless your butt dyno is unusually sensitive, there's no major difference either way
Old May 7, 2004 | 10:14 PM
Boges's Avatar
Default Re: Should I use Denso Iridium or NGK platinum.....for my ITR. (SLCTyper)
I went from the NGK platinums to Denso Iridiums. I honestly can't tell any difference between the two performance wise, i doubt there is much. Just go with whatever you get cheaper.
Old May 7, 2004 | 10:39 PM
RTW DC2R's Avatar
im using the iridiums, no complaints.
http://www.sparkplugs.com $7 each
Old May 8, 2004 | 05:08 AM
Tweakmeister's Avatar
Default Re: (RTW DC2)
http://www.clubplug.net NGK Laser Platinum
1sikhatch
Feb 25, 2007 02:51 PM
louie3252
16
Mar 20, 2006 11:07 PM
Chillinit
Oct 24, 2005 10:00 PM
gsr98vtec
Apr 25, 2002 12:11 PM
RaVAGE00
Apr 6, 2002 10:36 PM
