Pictures of my new stuff and improved W/A setup....
Old May 7, 2004 | 05:02 PM
SiR Kid's Avatar
New User
Default Pictures of my new stuff and improved W/A setup....
Got the camera out and took some more pictures...
Mods list:
B16a, Endyne .020" over ceramic coated pistons, eagle rods, STR blockguard
Inline pro manifold, custom WG elbow, custom 2.5" to 3" dp
Precision SC34 turbo, Tial 35mm WG, Spearco w/a intercooler, Permacool heat exchanger, all custom lines and reservoir.
This heat exchanger came in yesterday, so I ran to Godman's Performance for the fittings today and got it installed... Everything tested out, no leaks in the water system, so we'll see how she does at the track in a few more weeks after she's tuned and aligned...
Here's the engine bay, how it looks right now...
Here's a comparo of the old and new heat exchangers... I'm trying to make sure temps stay down ont he water system, so I can truly call this a "street setup".... I'm thinking about breaking out some flat back paint, and hit the fins somewhat to hide it behind the bumper a little better.
Here's some random clearance pics for ground clearance, turbo to radiator clearance, and how my oil return had to be routed... No problems so far, and it hasn't made a puff of smoke yet, so I think she's MUCH happier with the new turbo than the old one.
Old May 7, 2004 | 05:11 PM
Ben Huynh's Avatar
Default Re: Pictures of my new stuff and improved W/A setup.... (SiR Kid)
Jody, looking good!
Old May 7, 2004 | 05:21 PM
hulkhb's Avatar
Default Re: Pictures of my new stuff and improved W/A setup.... (ben@importparts.com)
pretty dope setup man
Old May 7, 2004 | 05:22 PM
liam821's Avatar
very cool!! Im liking the setup!
liam
Old May 7, 2004 | 08:15 PM
onePOINTsix's Avatar
Default Re: Pictures of my new stuff and improved W/A setup.... (liam821)
damn that hott what A/W IC is that? Is it a custom one? Eather way baddass!
Old May 7, 2004 | 10:02 PM
SiR Kid's Avatar
New User
Default Re: Pictures of my new stuff and improved W/A setup.... (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">damn that hott what A/W IC is that? Is it a custom one? Eather way baddass! </TD></TR></TABLE>
Spearco 252-1 if I'm not mistaken, can't remember... VERY small core. Perfect for a 300-350 hp street car.
Old May 8, 2004 | 09:39 AM
SiRkid's Avatar
ahhhhhhh 2 SiRkid's.
Old May 8, 2004 | 11:56 AM
SiR Kid's Avatar
New User
Default Re: Pictures of my new stuff and improved W/A setup.... (SiRkid)
Always has been, always will be.
Old May 9, 2004 | 10:50 AM
DD_JonnyLee's Avatar
clean
Old May 9, 2004 | 10:58 AM
G
sh!t happens.
Default Re: Pictures of my new stuff and improved W/A setup.... (GitrDone)
how do you like that intercooler system?
Old May 9, 2004 | 12:26 PM
91' LS-VTEC's Avatar
Default Re: Pictures of my new stuff and improved W/A setup.... (G"UNIT)
very nice set-up. can't wate to see some WHP #'s and track times
Old May 9, 2004 | 12:40 PM
b16crx1's Avatar
is it me or is your motor slanted a little to the drivers side? btw that looks badass good luck
Old May 9, 2004 | 01:24 PM
SiR Kid's Avatar
New User
Default Re: (b16crx1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx1 &raquo;</TD></TR><TR><TD CLASS="quote">is it me or is your motor slanted a little to the drivers side? btw that looks badass good luck </TD></TR></TABLE>
It's an optical illusion... Motor is flat, the intercooler droops slightly to the passenger side because of the hood renforcements.
Old May 9, 2004 | 05:26 PM
Adi Radoncic's Avatar
On Fire!
Nice little setup!!
What brand and size is that exchanger?? Also where did you get it from?
Old May 9, 2004 | 06:56 PM
BoostedSi's Avatar
Default Re: Pictures of my new stuff and improved W/A setup.... (newgsr just D.T.P)
nice setup
Old May 9, 2004 | 07:02 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Pictures of my new stuff and improved W/A setup.... (BoostedSi)
Did you use your stock radiator? and what X-member are you using?
Old May 9, 2004 | 10:25 PM
SiR Kid's Avatar
New User
Default Re: Pictures of my new stuff and improved W/A setup.... (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr just D.T.P &raquo;</TD></TR><TR><TD CLASS="quote">What brand and size is that exchanger?? Also where did you get it from?</TD></TR></TABLE>
PermaCool exchanger... 10x1.5x21, I believe. $100 from Summit Racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Did you use your stock radiator? and what X-member are you using?</TD></TR></TABLE>
Stock style radiator.. brass cores, though from 1-800-RADIATOR. Jimfab traction bars that still need to be adjusted, apparently. Gets wobbly at high speeds... not enough caster.
Old May 10, 2004 | 03:31 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">
Stock style radiator.. brass cores, though from 1-800-RADIATOR. Jimfab traction bars that still need to be adjusted, apparently. Gets wobbly at high speeds... not enough caster. </TD></TR></TABLE>
Cool so do you think my Inline-Pro/SC61 will clear the stock radiator?
Old May 10, 2004 | 06:59 AM
.nate's Avatar
W00t! Looks great Jody! Gimme a ride dammit!
Old May 10, 2004 | 05:29 PM
SiR Kid's Avatar
New User
Physically, my SC34, and the SC61 are externally the same size... jsut a difference in compressor and turbine wheels and openings, not housing diameters.
SC61 is my next bolt on upgrade when I go big bore/stroker.
SiR Kid's Avatar
New User
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">W00t! Looks great Jody! Gimme a ride dammit! </TD></TR></TABLE>
help me figure out why my car keeps dying, and I will!
Old May 10, 2004 | 06:29 PM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Physically, my SC34, and the SC61 are externally the same size... jsut a difference in compressor and turbine wheels and openings, not housing diameters.
SC61 is my next bolt on upgrade when I go big bore/stroker.</TD></TR></TABLE>
Cool
a1320honda
Nov 4, 2012 05:31 PM
cwest_ek
Feb 1, 2010 10:09 AM
bads2k
105
Jan 20, 2008 07:27 PM
SiR Kid
25
May 9, 2004 09:27 PM
igo4bmx
Dec 18, 2003 11:48 AM
