How reliable is a 2.0L?
Old May 7, 2004 | 02:09 PM
Blazeone's Avatar
Default How reliable is a 2.0L?
Well my B18C5 gernaded on me, and the sleeve is ruined in the #2 cylinder. I was wondering how streetable/reliable a sleeved 84-85mm engine is?
Old May 7, 2004 | 02:10 PM
BlackThorN's Avatar
depends how aggressive you take it
it can be more so then a stock motor, or it can be a huge rough pain in the ***
it depends how you build it
Casey's Avatar
Default Re: How reliable is a 2.0L? (BlazeONE)
very as long as proper tuning is done
Old May 7, 2004 | 02:24 PM
Blazeone's Avatar
Default Re: How reliable is a 2.0L? (Casey)
hmm, skunk2 stage 2 cams etc with bolt ons, just around 200whp ish.. My old motor was kind of a headache, just want this one to be good.
Old May 7, 2004 | 02:29 PM
Casey's Avatar
it can be very reliable if all youre shooting for is 200. You can run relatively low(high 10, low 11) compression to accomplish that.
Old May 7, 2004 | 04:36 PM
Blazeone's Avatar
My previous build had 11.5:1 compression on 91 octane, seemed good, no detonation or pinging.
Would the combustion chamber also have to enlarged because to the larger bore?
Old May 7, 2004 | 07:51 PM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlazeONE &raquo;</TD></TR><TR><TD CLASS="quote">My previous build had 11.5:1 compression on 91 octane, seemed good, no detonation or pinging.
Would the combustion chamber also have to enlarged because to the larger bore? </TD></TR></TABLE>
no, youll lose a lot of compression
Old May 7, 2004 | 07:53 PM
BlackThorN's Avatar
I"ll let you know when my friend's 2.0 with toda B's get's tuned by SGT
Old May 8, 2004 | 09:17 AM
Blazeone's Avatar
So no extra headwork is needed, would i still use the the same oem style headgasket or another aftermarket one(i had a spoon 2 ply before)...
Old May 8, 2004 | 10:25 AM
FATBOYeg6's Avatar
i thought with a larger bore, you have to enlarge the combustion chambers on the head? you also can't use a stock headgasket if im not mistaken. someone correct me if i am wrong.
Old May 8, 2004 | 10:41 AM
BlackThorN's Avatar
with a 2.0 you would need a different headgasket if you enlarge the bore
several companies make them
cometic and others
I don't think you have to enlarge the head, but you can if you want, and that would help I assume
Nick
Old May 8, 2004 | 01:04 PM
Casey's Avatar
Default Re: (BlackThorN)
you need a larger bore head gasket. but boring out the combustion chambers will not help. take my word for it, or ask around...the only person that does this is larry at endyn. I listen to brad at RLZ, and he told me he did a comparision and it hurts performance more than helping it
Old May 8, 2004 | 03:32 PM
FATBOYeg6's Avatar
Default Re: (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">you need a larger bore head gasket. but boring out the combustion chambers will not help. take my word for it, or ask around...the only person that does this is larry at endyn. I listen to brad at RLZ, and he told me he did a comparision and it hurts performance more than helping it</TD></TR></TABLE>
really. maybe i was reading old information, or possibly only getting one opinion. thanks. do you know if that would effect compression at all? i would think boring out the head to match the piston bore would lower the compression a little with the same piston?
Old May 8, 2004 | 03:49 PM
Casey's Avatar
Default Re: (ninefivehatch)
it will lower it quite a bit. think about how much compression you get by using a 2 layer head gasket which is 1 layer thinner than stock(you gain .4 in comp or around there)...and how thin 1 of those layers is. Youre taking out a lot more material from the head. When brad ported my head, he milled it .025 just to bring it back up to stock compression, if he hadnt, then it would have picked up .7 in compression
steveteggy92
12
Mar 31, 2008 02:39 PM
dohcMONSTER
12
Apr 1, 2006 08:24 AM
Dmc1
15
Feb 6, 2006 11:06 PM
24K SI
Sep 3, 2004 07:40 AM
desert eagle
Aug 6, 2003 02:05 PM
