Valves? which one is which?
Old May 7, 2004 | 01:58 PM
Civicr2gs5's Avatar
Default Valves? which one is which?
hey everyone...i'm about to install some new skunk2 valves but i'm not sure which one are which. there are two different size valves, which one is which for the intake and exhaust? thanks any feedbacks helps
Old May 10, 2004 | 08:22 PM
B18Tahtaras's Avatar
Default Re: Valves? which one is which? (Civicr2gs5)
intake is larger.
Old May 10, 2004 | 08:24 PM
elwood's Avatar
Default Re: Valves? which one is which? (B18Tahtaras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras &raquo;</TD></TR><TR><TD CLASS="quote">intake is larger. </TD></TR></TABLE>
That may be true for automotive engines, I dont
know the answer, but I do know that on small gas
engines that the exaust valve is lager.
Old May 10, 2004 | 08:49 PM
BatuKing's Avatar
When you take them off you will know which is which.
Old May 10, 2004 | 09:25 PM
usdmike's Avatar
Intake is larger, as long as they're like these.....
http://www.arizonazcar.com/valves.html
Old May 18, 2004 | 04:29 PM
Default Re: Valves? which one is which? (elwood)
The intake to exhaust valve ratio is right around 3:2 on most engines give or take...
Old May 18, 2004 | 05:25 PM
SOHC4life 96's Avatar
Default Re: (Dimi)
dont the owners manuals that come with the cars tell you the intake and exhaust valve diameters? but correct me if im wrong.
Old May 18, 2004 | 05:51 PM
CivicSiRracer69's Avatar
Default Re: (DOHC4life)
while reading this post I found my self picking my nose and thinking about those lil Wooden dowels when you were a kid with the shapes, lol They will only fit in the right holes... lol Same in this circumstance. Not to bash or flame or anything bro, but use your head, they will only fit one way.
Old May 18, 2004 | 06:44 PM
Miracle Swap16's Avatar
you bought new valves but you might want to lap the valves so that they seat on the valve seat well. You get the lapping compound and a small valve plunger. Put the lapping compound on the part of the valve where the valve seats, put the valve back into the head, turn cylinder head over, combustion chambers facing up, put plunger onto bottom of valve, lift up valve and smash back down, then turn several times, lift up and smash again, turn several times, repeat repeat repeat until lapping compound is gone and then do for all valves. Then you be ready for propper installation.
sup3rd
Nov 26, 2007 06:30 PM
tmmyby83120
Mar 15, 2007 09:01 AM
breathinez
Aug 24, 2004 10:35 AM
Boost2NA
Apr 20, 2004 06:06 PM
baonest
May 30, 2002 05:13 PM
