Built H22 ECU Questions.
Old May 7, 2004 | 11:55 AM
98TypeSH's Avatar
Default Built H22 ECU Questions.
I have a built Jun head on my lude. Port and polished, milled, jun cam shafts, retainers, valve springs, skunk2 cam gears and a VAFC. This is all in the process of a 2-3 week long build. Ive been reading alot about ecu's and have read that the p72 would be the best choice due to the IAB's and the fact that there is tons of programs and chips out for it. Would this be a wise decision? or should i stick with a p13 ? If i ever decide to go hondata with the p13 i believe there are no programs available or so ive read on the essential links.
Thanks for any and all help/advice.
Old May 7, 2004 | 01:42 PM
98TypeSH's Avatar
Default Re: Built H22 ECU Questions. (98TypeSH)
any input ?
Old May 7, 2004 | 01:51 PM
Kal's Avatar
Kal
well there's always AEM EMS... it allows for itb running too plus it's in the lines of hondata.
Old May 7, 2004 | 04:43 PM
98TypeSH's Avatar
Default Re: Built H22 ECU Questions. (Kal)
goin up again. someone has to have an idea with their all motor h22 and the right ecu to run. i want my secondaries and my ABS.
Old May 7, 2004 | 05:12 PM
Speedra500's Avatar
yes the p72 is a good choice, I am building a very heavily modified NA setup and I am planning on running a p72 hondata you can use all your options, or a p30 will give you everything besides IAB control, but it has the knock sensor and all that good stuff, oh yea you can get the p13 hondata which is fully programmable so you dont have to worry about those chipping programs that dont even work all that well anyway
Old May 7, 2004 | 06:55 PM
jdmcivicferio's Avatar
Default Re: Built H22 ECU Questions. (Speedra500)
P28, best ECU
Old May 7, 2004 | 07:15 PM
builtprelude's Avatar
yah I'm running a p72 with my hondata and it has worked well so far. It is the more expensive ecu but it is better
Old May 7, 2004 | 07:34 PM
LudeDewd's Avatar
Default Re: (builtprelude)
im guessing you no longer have ATTS
Old May 7, 2004 | 11:27 PM
Default Re: (LudeDewd)
Mine is the base I never had atts to begin with which I think is better for me
Old May 8, 2004 | 06:48 AM
LudeDewd's Avatar
i meant mr. 98typeSH the guy who started the thread.
Old May 8, 2004 | 11:29 AM
98TypeSH's Avatar
yea im willing to part with it, otherwise i wouldent be building the f out of my motor
Old May 8, 2004 | 11:30 AM
satan_srv's Avatar
yeah buddy if you change your ecu your ATTS system won't work anymore...just 50-60 pounds of dead weight
And a built head is not a built h22a...
and your ecu is a p5p not a p13
p72 will not help you, nor will the chips.
just tune the v-afc
Old May 8, 2004 | 11:44 AM
98TypeSH's Avatar
Default Re: (satan_srv)
all im doing at this moment in time i building the head. i have plans dont worry about that. im looking in the long run, if a p72 will benifit my setup. i just didnt feel like dropped anymore money right now, chill.
Old May 8, 2004 | 11:56 AM
satan_srv's Avatar
Default Re: (98TypeSH)
a p72 will not benefit your setup
Old May 8, 2004 | 03:45 PM
afterburners's Avatar
there are a few p13 maps/roms out there I have a few, spoon, mugen, stock maps. These combinations are up to you and I don't think anyone can say anything bad about any one unless they have test each setup and I doubt that. So the best way to put it is what option are there. p28civic dohc vtec(running a p13map) , p13usdm hondata piggy, p13hodata full ecu, p72gsr w/hondata piggy. These are probably your best choices. Good to have knock sensor, iab. good to get rid of egr, eld.
HAccord96
Oct 10, 2007 09:49 AM
spoonzdelsol
Mar 6, 2006 05:32 PM
tuan...
Feb 9, 2004 05:18 AM
tuan...
Dec 28, 2003 07:48 AM
fastwanabe
May 10, 2003 07:03 AM
