How long should I leave aircraft paint striper on aluminum rims?
Old May 7, 2004 | 11:20 AM
EJ1_519
Guest
Posts: n/a
Default How long should I leave aircraft paint striper on aluminum rims?
Hey guys, I just bought Aircraft paint striper so I can remove the paint off my rims.
I'm just wondering how long should I leave the paint striper on the rims for? Reason I'm asking is because at NAPA the guy told me not to use this on aluminum rims and said it will damage the rim
thank
Old May 7, 2004 | 11:25 AM
Transport's Avatar
Default Re: How long should I leave aircraft paint striper on aluminum rims? (EJ1_519)
read directions or leave it until you see the paint buble/peel/lift...
Old May 7, 2004 | 11:48 AM
nightrider's Avatar
10-15 minutes should do it i believe. not sure, but check out this thread.
https://honda-tech.com/zerothread?id=792808
Old May 7, 2004 | 11:49 AM
lak8's Avatar
well i never used "Aircraft paint striper" but some other brand name stuff from walmart and i let it sit for about 15-20mins as it says on the can. also it really depends on the paint it self. The clear coat came off just about as fast as you can put the remover on but the paint itself took about 10mins. Dunno about the stuff yor using but the stuff i used you can basicly let the stuff dry and it would do any damage to the alm, just makes it harder to get off.
aznxguyx89
Aug 30, 2007 08:49 PM
tegda
Mar 12, 2007 06:25 AM
civicb18turbo
22
Mar 4, 2004 09:22 AM
PoWeRBaN_PaNdA
Apr 30, 2002 11:01 PM
