gsr lca on eg hatch question
Old May 7, 2004 | 11:01 AM
daver's Avatar
Default gsr lca on eg hatch question
well i just ordered brand new 1994 gsr rear lower control arms (with bushings) and the gsr bolts for my '94 hatch. I just want to confirm fitment.
I know the lca's fit (they say), but are the gsr bolts the same as the eg's?
Does the gsr lca change the camber at all? ie. are they a slightly different length at all?
Is there anything else i need to make them work? I'm just in a tight squeeze and i want to make sure i've got all the bits and pieces i need. I was just trying to install some shocks and i had to chop up the old lca's bolts and bushings pretty bad to get them off.
thanks,
d
Old May 7, 2004 | 12:13 PM
EL Vap133's Avatar
Default Re: gsr lca on eg hatch question (daver)
Bolts are the same.
Old May 7, 2004 | 12:46 PM
silverEH2's Avatar
Default Re: gsr lca on eg hatch question (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Bolts are the same. </TD></TR></TABLE>
yep got a set on my coupe
Old May 11, 2004 | 10:14 PM
daver's Avatar
Default Re: gsr lca on eg hatch question (silverEH2)
thanks guys, got it all installed now.
d
Old Jun 1, 2004 | 01:48 PM
BLUE EH3's Avatar
Help we my pennies
is this statement true? 94-01 Integra and 92-95 Civic LCAs are interchangeable
Old Jun 1, 2004 | 02:12 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: gsr lca on eg hatch question (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">is this statement true? 94-01 Integra and 92-95 Civic LCAs are interchangeable</TD></TR></TABLE>
100% true. i'm running GSR LCAs as well as a GSR rear sway bar on my del sol.
94-01 integra LCAs=92-95 civic LCAs=93-97 del sol LCAs
only difference is some come equipped with the hole for a stock rear sway bar, but that's the only difference.
superdat1
Oct 30, 2007 11:59 AM
BMo Tuning
Aug 18, 2006 08:01 AM
JJW
Jan 20, 2005 04:16 PM
-DC2-
Sep 16, 2004 12:31 PM
