Oil leak at the tip of the head?
Old May 7, 2004 | 06:07 AM
trooper0641's Avatar
Default Oil leak at the tip of the head?
I just realized i have a small oil leak at the tip of the head...where the head meets the block. How can i fix it? Can i just seal it with silicone sealant from the outside?
Old May 7, 2004 | 06:23 AM
Default Re: Oil leak at the tip of the head? (trooper0641)
ttt
Old May 7, 2004 | 06:32 AM
Echo7847's Avatar
which side, take pics.
Old May 7, 2004 | 06:39 AM
Louie_EM1
Guest
Posts: n/a
Default Re: Oil leak at the tip of the head? (Echo7847)
WHAAAAAAAAAAAAAAAT?
Tip of the head where the head meets the block? rofl.
Oh just like the toes on my hands.
Your question makes no sense.
Im going to take a guess you're tlaking about your valve cover which is notrious for doing. In this case, you take your cover off go to Honda buy a valve cover gasket ~8 bucks (Oh and get some plug o-rings too just cause it's a saftey measure ~ 4 bucks) and a tube of Hondabond ~12 bucks. Then replace the gasket(s) and put the Hondabond on the corners of the cam seal(s).
Old May 7, 2004 | 06:57 AM
Default Re: Oil leak at the tip of the head? (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">WHAAAAAAAAAAAAAAAT?
no, i know what a valve cover is. i dont know how to describe this...but its leaking from the head.
Old May 7, 2004 | 06:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">which side, take pics.</TD></TR></TABLE>
the left side, no camera.
Old May 7, 2004 | 06:59 AM
BauleyCivic's Avatar
Risky Business
If its on the passenger side its either the valve cover gasket, dizzy o-ring, or vtec solenoid gasket. For me it was the vtec solenoid gasket.
Old May 7, 2004 | 07:00 AM
RangerDan's Avatar
Distributor side? At least does it appear it may be originating from there. If so just replace the o ring. Very common.
Old May 7, 2004 | 07:22 AM
Louie_EM1
Guest
Posts: n/a
Default Re: Oil leak at the tip of the head? (RangerDan)
Oh so you're talking about the corner as in the 'tip'?
Take the valve cover off and replace the cam seal(s) and gaskets like the other guys said.
Old May 7, 2004 | 07:43 AM
well...ahh...its not that...ill try to take some pictures.
Old May 7, 2004 | 09:03 AM
Echo7847's Avatar
Could be the dizzy o-ring seal, cam seal, vtec solenoid gasket if you have one.
Old May 7, 2004 | 09:09 AM
Risky Business
Mind you guys that SOHC's dont have cam seals on the dizzy side...just the o-ring.
Old May 7, 2004 | 09:16 AM
moto27cm's Avatar
Dont overlook the head gasket. I have seen really slow leaks at the base of the head on the front left corner of the motor.
Old May 7, 2004 | 11:38 AM
Default Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm &raquo;</TD></TR><TR><TD CLASS="quote">Dont overlook the head gasket. I have seen really slow leaks at the base of the head on the front left corner of the motor.</TD></TR></TABLE>
Yes this guy is right...i have this type of leak.
Old May 7, 2004 | 12:16 PM
RangerDan's Avatar
Default Re: (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes this guy is right...i have this type of leak.</TD></TR></TABLE>
This may in fact be the case...but look into the cheapest/easiest thing first. Comp. check will tell.
Old May 7, 2004 | 12:25 PM
NextGenRacing's Avatar
I just fixed this same probem on my car. It is the head gasket and it will need to be replaced. Its also a good time to consider using a thinner gasket, to try and pick up any little bit of extra compression that you can. Don't forger that you shouldn't reuse your head bolt, and will be a lot better off to just replace them (all 10).
Best of Luck,
Old May 7, 2004 | 12:28 PM
Default Re: Oil leak at the tip of the head? (NextGenRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextGenRacing &raquo;</TD></TR><TR><TD CLASS="quote">I just fixed this same probem on my car. It is the head gasket and it will need to be replaced. Its also a good time to consider using a thinner gasket, to try and pick up any little bit of extra compression that you can. Don't forger that you shouldn't reuse your head bolt, and will be a lot better off to just replace them (all 10).
Best of Luck,</TD></TR></TABLE>
thinner head gasket? didnt i hear something about using the y8 head gaskets? what do they do? i have a d15b
Old May 7, 2004 | 05:50 PM
TeamCracka's Avatar
He's clearly talking about the head gasket ("where the head and block meet").
I have always had a small amount of oil sepage from the front left corner of the block, where there's a corner of the HG poking out. I doesnt come out enough to ever drip or run down the block, but it does reappear if I wipe it away.
It's not a big deal, unless you have coolant in your oil or oil in your coolant, you should maybe try a compression check.
Old May 10, 2004 | 01:10 PM
Default Re: Oil leak at the tip of the head? (TeamCracka)
i think im losing compression...for some reason my motor feels "slower" than before...
Old May 10, 2004 | 01:31 PM
By using a thinner gasket you can accomplish two things:
1. Less space between the head and block, thus a tighter seal and less chance of seepage.
2. Slightly increased compression ratio, due to the piston having to travel a shorter distance to reach TDC.
The y8 gasket is used on the D16s, but if your running a D15 JDM like me, APEX makes a great graphite gasket that will be thinner than stock.
Hope this helps,
Old May 10, 2004 | 02:59 PM
dam is it possible to loose compression...having a "bad" head gasket with just a little bit of oil leak at the corner?
Old May 10, 2004 | 03:25 PM
what do they mean by taking out the "middle" layer of the d16y8 head gasket to bump up the compression? How many layers does a head gasket have? I thought it was just a peice like a intake or a exhaust gasket?
Old May 10, 2004 | 03:54 PM
ttt
Old May 10, 2004 | 05:33 PM
23rweasdf3wev
Old May 10, 2004 | 09:40 PM
ttt
