autotensioner
Old May 6, 2004 | 07:51 PM
jackstands's Avatar
Default autotensioner
Has anyone ever heard of two new autotensioners going bad? I've recently replaced my autotensioner twice, brand new ones from the factory because my timing belt kept slapping. The first thousand miles or so were fine, then the belt just starts slapping the timing cover. The motor is built, but the head was milled. Here's a question, when I got it from the dealership, did I have to add oil. It was in a sealed bag. Ideas?? I'm stumped, and am tired of having to drop 150 bucks every thousand miles to do my timing belt again.
Old May 6, 2004 | 07:56 PM
@ries's Avatar
Default Re: autotensioner (jackstands)
Why don't you just do the manual tensioner (from a H23) swap and call it a day?
Old May 7, 2004 | 02:27 PM
jackstands's Avatar
Default Re: autotensioner (@ries)
don't have the money nor time to swap over, thought about it but parts will cost me another 2 hundred, and I'm already way over my build budget. anyone got any good suggestions.
Old May 7, 2004 | 03:10 PM
Revi's Avatar
The tensioner comes from factory with the necessary oil already in it. It should of came compressed and held down with a metal bracket. Do you know about the new and "remanufactured" Tensioner/Timming belt kit Honda has now? My autotensioner failed and was replaced only to have it fail within a year again. I ordered the remanufactured one and ive had no problems since. I cant remmemeber the part number but i you do a search im sure it will come up.
Old May 7, 2004 | 04:48 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackstands &raquo;</TD></TR><TR><TD CLASS="quote">don't have the money nor time to swap over, thought about it but parts will cost me another 2 hundred, and I'm already way over my build budget. anyone got any good suggestions.</TD></TR></TABLE>
no they wont parts are like 150 shipped:
Old May 7, 2004 | 07:15 PM
jackstands's Avatar
Default Re: autotensioner (Revi-Ra)
No i don't. The dealership replaced the autotensioner for free. I asked them if the ones they sold me were the replacements for the bad 1st design. they said yes, but i have the distinct feeling they didn't know what i was talking about. How were these tensioners remanufactured, and where do i get them?
Old May 8, 2004 | 12:10 AM
89sih22a's Avatar
slapping the timing cover?do yo mean at idle or at higher rpm?
when i rev my engine under the hood i noticed the timing belt seems to look like it
\wiggles when i rev it is that normal ,someone?
Old May 8, 2004 | 06:51 AM
LudeDewd's Avatar
Default Re: autotensioner (lude_angel)
i had mine done at 73k at honda.. im at 88k and i think i will need to be replacing this damn tensioner again. Its really making me think about selling it. btw its a 97 SH
Old May 8, 2004 | 08:05 AM
TypeRKoncepts's Avatar
ironically i was just searching for some manual tensioner threads... sorry to jack your thread but can sumone list the parts needed for the conversion and any DIY instructions for it?
Old May 8, 2004 | 05:11 PM
rjr162's Avatar
Default Re: (TypeRKoncepts)
just an FYI, there is a TSB for the autotensioners on the 5th gen H22A4's... they are known to fail prematurely, though I can't quite say prematurely was ment to mean 1000 miles lol
Old May 8, 2004 | 05:31 PM
afterburners's Avatar
Default Re: (rjr162)
109818 030 1 WASHER, PLAIN (11MM) 3.02 2.30
34257 027 1 7.98 6.06
34256 026 1 6.73 5.11
109817 025 1 3.63 2.76
109816 020 1 PLATE, ADJUSTER 9.60 7.30
109815 019 1 SPRING 3.83 2.91
34254 018 1 ADJUSTER 64.10 48.72
34247 010 1 ADJUSTER 65.95 50.12
$125.48
http://www.hondaautomotivepart...0.gif
These parts replace your existing parts and its that simple. Consider it an insurance.
Numbers represent hondaautomotiveparts.com prices at the end. the part #'s are there references and are not that of the dealership.
Old May 8, 2004 | 09:36 PM
satan_srv's Avatar
Default Re: (afterburners)
Honda sells a new autotensioner kit that replaces all the old parts, there was a TSB (already mentioned)
Old May 9, 2004 | 12:18 AM
KTeller8's Avatar
13404-PT0-004 - balancer belt adjuster
14510-PT0-004 - timing belt adjuster
14516-PT2-000 - adjuster spring
90014-P14-A00 - adjuster base bolt
90015-PT0-000 - adjuster spring bolt
90016-PT0-000 - adjuster bolt
90140-P14-A00 - 11mm washer
14521-P14-A00 - adjuster plate
depends where you go, but if it takes more then 150 out the door; then head here:
http://www.kteller.com/store/p...d=647
Old May 9, 2004 | 12:37 AM
sharkcohen's Avatar
Default Re: (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">13404-PT0-004 - balancer belt adjuster
http://www.kteller.com/store/p...d=647</TD></TR></TABLE>
Woah, is that everything needed?
Old May 9, 2004 | 04:35 AM
jackstands's Avatar
Jesus, I wish I'd seen KTeller's link earlier. The autotensioner and the two timing belts I had to buy would've cost more than that swap. If the autotensioner screws up on me again, I've got your website bookmarked. Thanks again. I'm running AEM cam gears so I mooncut my upper timing cover and valve cover, someone told me that if I do that, then I have to remove the seal from the lower timing cover so if anything bits of dirt, debris or water get inside from up top, it can escape through the bottom. Any one ever heard of this.
Random question, when I was changing the belt, I noticed an oil residue from around the head gasket area, is that my head gasket starting to give. I built my motor a little more than a 5000 miles ago. Is it the ARP studs, do they have to be retorqued? Any advice would give me some peace of mind. Thanks
Old May 9, 2004 | 12:03 PM
Default Re: (jackstands)
I just posted it was $125, why don't you guys see that?
Old May 9, 2004 | 06:28 PM
KTeller8's Avatar
Default Re: (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Woah, is that everything needed?</TD></TR></TABLE>
Not 100% sure, ive never did the swap personally, that is a list ive complied from many sources and its exactly the same as the one listed up above with the wacky part numbers
Old May 9, 2004 | 08:26 PM
Variable J's Avatar
I recently did the swap on my h22a4. The only parts I used were the pulley from the h23 the three bolts and the spring. Simply reuse the h22 balancer belt pulley use washers to shim it so it clears the other pulley that way you dont have to use the plate adjuster.
msnewman
Jul 19, 2012 05:13 AM
woo78f
Sep 26, 2006 07:44 AM
ChicagoEGCoupe
17
Sep 16, 2006 09:28 PM
xenoxnty
Mar 23, 2004 11:55 AM
dogpile5
18
Nov 6, 2002 09:01 AM
