flywheel is grinding against tranny case!
Old May 6, 2004 | 07:35 PM
kreate305's Avatar
Default flywheel is grinding against tranny case!
as i said in the topic, the flywheel is grinding against the tranny case. it made a pretty deep groove in it even though it ran for about 1 min. the car is a 93 lude that originally had an h23 w/ manual tranny. that engine blew up and it is being replaced by a 94 h23/vtec that came from an automatic car. the tranny, flywheel, clutch and p.p. are all the same as when the car ran well. i am baffeled as to what it is that is cuasing this clearance issue. has anyone ever had a problem like this?
Old May 6, 2004 | 10:28 PM
VTECR021's Avatar
Default Re: flywheel is grinding against tranny case! (kreate305)
proably wrong flywheel, or flywheel not tightened up properly.
Old May 6, 2004 | 11:14 PM
Matgallis's Avatar
Default Re: flywheel is grinding against tranny case! (VTECR021)
maybe an h22 flywheel was put on by accident? If there is actually a difference.
Old May 7, 2004 | 04:08 AM
PirateMcFred's Avatar
Default Re: flywheel is grinding against tranny case! (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">maybe an h22 flywheel was put on by accident? If there is actually a difference.</TD></TR></TABLE>
there's no difference...
Old May 9, 2004 | 05:26 AM
93H22ACX's Avatar
Default Re: flywheel is grinding against tranny case! (PirateMcFred)
no difference at all. I have a h22 flywheel, clutch, throw out bearing, and pp on my H23 block.
Old May 9, 2004 | 10:02 AM
LudaMan's Avatar
Look what I can do!
id make sure the flywheel was tightened first before anything, that would be my only guess
1INTEGRA
Jan 19, 2006 04:43 PM
sol_1320
25
Oct 4, 2005 02:35 PM
numotive
Sep 21, 2005 04:37 PM
SKDRCR
Jul 23, 2004 10:56 AM
h23turbo
Jul 17, 2004 02:35 PM
