SEPERATE AMPs for tweeters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">do you have them crossed over? Are they powered by the deck?</TD></TR></TABLE>
i have a coustic xm-6 but they arent on them now, waiting to run them on one side of my amp and then using a seperate channel on the x over for them
and HELL NO they are not powered by the deck
a punch 160.4 amp is playing the mids and tweets, i was thinking of using it just for the tweets
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan-boxer »</TD></TR><TR><TD CLASS="quote">but they are rated at 150 rms
and techinally they are getting 20 rms watts
from my punch 160.4
EXPLAIN THAT!
clipped signal
from my punch 160.4
EXPLAIN THAT!
</TD></TR></TABLE>clipped signal
ok
so if 20-30 watts is enough for tweeters i should get an amp that pushes 20 -30 watts?
that would be kind of hard
couldnt i just turn down my 160.4 and use it just for 4 tweeters
Exactly..... Get in your ride, turn amp gains all the way down. Turn your deck up most of the way(say max volume is 30, go to 27-28). Put in a nice, cleanly recorded track(no burned cd's). Slowly turn up the amp gains until it barely starts to distort, then back it off a little. Depending on the tweeters, set the crossover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNDAPWR »</TD></TR><TR><TD CLASS="quote">Exactly..... Get in your ride, turn amp gains all the way down. Turn your deck up most of the way(say max volume is 30, go to 27-28). Put in a nice, cleanly recorded track(no burned cd's). Slowly turn up the amp gains until it barely starts to distort, then back it off a little. Depending on the tweeters, set the crossover.</TD></TR></TABLE>
ive done that many times and they still cut out, they cut out when the amp is at minumum at volume 30 out of 35
how am i cliping the signal as earlier said?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">So you aren't using the crossovers? What are you using to high-pass the tweeters? </TD></TR></TABLE>
yeah i was using the crossovers that came with them, i blew one
so im using the other one wothout the crossover, hope i blow it too
going to buy some dhd tweeters with crossovers
jjzend600rr
Audio / Security / Video
Sep 17, 2007 12:18 PM
