Well, I figured out why my car wasn't boosting right.....
Old May 6, 2004 | 06:22 PM
Boost Addict's Avatar
Default Well, I figured out why my car wasn't boosting right.....
I was checking all my hoses, and this is the clamp connecting the charge pipe and the turbo:
It was too close to the manifold and fried it. Any ideas on what kind of clamp I should use instead? I need something that won't get burnt up like this one.
Old May 6, 2004 | 06:32 PM
Turboteggy's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (xPRELUDEx)
Not sure where you can get these, but they have a metal sleeve over the hose -should protect it from heat. Try a heavy truck/machinery shop.
Old May 6, 2004 | 06:39 PM
1316130057's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (Turboteggy)
Or you could use silicone tubing which won't burn or catch fire no matter what you do. Rejects heat internally as well.
Old May 6, 2004 | 06:56 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">Not sure where you can get these, but they have a metal sleeve over the hose -should protect it from heat. Try a heavy truck/machinery shop.
looks like one of those spectra radiator hose wanna be stainless steel braided cover sets. they coem with the " ends" like that
Old May 6, 2004 | 07:28 PM
showtymers619's Avatar
* B A N N E D *
Default Re: Well, I figured out why my car wasn't boosting right..... (project dc2)
i would invest in some wraps
Old May 6, 2004 | 07:53 PM
Well, I just got some more basic hose from a local shop for temp use:
I know the same **** is gonna happen, but it should hold for a while. I'm gonna go and try to find something better in the next few days.
Old May 6, 2004 | 08:06 PM
racinskittle's Avatar
if that's gaseline hose...that stuff should hold for a LONG time.
Im running 10psi, and it's sitting RIGHT next to the ehxaust manifold. It has worked GREAT so far.
Old May 6, 2004 | 08:59 PM
ten_30's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (racinskittle)
i would suggest putting a piece of heatwrap in between the hose clamps and the hose on the side where it is close to the manifold.
Old May 6, 2004 | 10:38 PM
c jackson's Avatar
threes
why dont you get the ninety welded to the housing?
Old May 7, 2004 | 01:02 AM
JDMorgan's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson &raquo;</TD></TR><TR><TD CLASS="quote">why dont you get the ninety welded to the housing?</TD></TR></TABLE>
Old May 7, 2004 | 08:50 AM
808_civic's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (KraZEtEggIE)
I was gona say you can always clock the turbo
Old May 7, 2004 | 09:06 AM
G
sh!t happens.
Default Re: Well, I figured out why my car wasn't boosting right..... (808_civic)
maake a heat sheild for it.. it wouldnt be hard..
Old May 7, 2004 | 09:43 AM
tgreaves's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (G"UNIT)
Holy boost leak batman..
Try making a heat shield out of sheet alumnium..
Old May 7, 2004 | 12:06 PM
Default Re: Well, I figured out why my car wasn't boosting right..... (tgreaves)
Try leaving it as it is first If it aint broke dont fix it. (he used a new pipe)
Old May 7, 2004 | 12:07 PM
SiRex91's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (1316130057)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">Or you could use silicone tubing which won't burn or catch fire no matter what you do. Rejects heat internally as well.</TD></TR></TABLE>
Old May 7, 2004 | 12:36 PM
boosted92's Avatar
Default Re: Well, I figured out why my car wasn't boosting right..... (SiRex91)
Maybe i'm thinking too baller-ish here, but what about V-band's?
Old May 7, 2004 | 12:40 PM
ludelvr's Avatar
If you have some spare exhaust heat wrap you should just wrap the coupling with it. I think either the fiberglass stuff or the shiny stuff would work fine!
Old May 7, 2004 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Holy boost leak batman..
Try making a heat shield out of sheet alumnium..</TD></TR></TABLE>
Well that's what I did. I had to go to the shop today, so while I was there I had them make a little sheild for it:
I think this should hold. Runs sooooo much better know that it's fixed. Thanks for the help, I let you guys know if the sheild works.
Old May 7, 2004 | 12:47 PM
VtecGSR's Avatar
nice turbo set up
Old May 7, 2004 | 03:27 PM
Default Re: Well, I figured out why my car wasn't boosting right..... (VtecGSR)
does anyone else have a sheild like this? Any pics?
Old May 7, 2004 | 08:56 PM
bump
Old May 7, 2004 | 09:13 PM
accordfreak's Avatar
i use hoses from atpturbo.com and the heat had no effect at all. my setup was almost just like yours..
Old May 8, 2004 | 01:20 AM
Tony the Tiger's Avatar
Should have used silicon couplers. Silicon can take tremendous heat. Heatshield, wrap, etc... is just too messy.
Old May 8, 2004 | 05:54 AM
tk's Avatar
tk
Try wraping the manifold and rubber with header wrap or make a heat shield.
Old May 8, 2004 | 04:30 PM
Default Re: (Tony the Tiger)
PlusOne
Welding / Fabrication
23
Sep 6, 2007 08:29 PM
11secteg
Apr 4, 2007 06:12 PM
DFW
Jan 9, 2007 11:03 AM
Evile140
Dec 27, 2005 01:01 PM
RudeLude
Mar 18, 2005 06:29 AM
