cluster and tail lights blew!?!!!
Old May 6, 2004 | 06:14 PM
1sikcoupe's Avatar
Default cluster and tail lights blew!?!!!
so im installing my jdm cluster i notice 1 of the bulbs are blown at the back of the cluster so i play with it and i little spark n smoke happen the cluster lights no longer turn on and my tail lights dont turn on either but my signals and brake and reverse lights still work im puzzled do u think its a fuse?
help is greatly apretiated
Old May 6, 2004 | 06:15 PM
99blackcivicSi's Avatar
Default Re: cluster and tail lights blew!?!!! (1sikcoupe)
you didn't check any of the fuses yet??? do that first
Old May 6, 2004 | 06:18 PM
1sikcoupe's Avatar
Default Re: cluster and tail lights blew!?!!! (99blackcivicSi)
i think its a fuse also but i wouldnt know which fuse to check or where to start
Old May 6, 2004 | 06:27 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i think its a fuse also but i wouldnt know which fuse to check or where to start
Underneath your dash on the driver side.. It's going to be the one that says '' tail light'' & ''instrument'' and it's going to be a 10 amp fuse.
Check to see if you popped it and come back to us..
1sikcoupe's Avatar
Default Re: cluster and tail lights blew!?!!! (Usdmdc2)
thanks guys i will do so
Old May 6, 2004 | 06:30 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikcoupe &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys i will do so</TD></TR></TABLE>
no problem..just hope thats all you did was blow a fuse
goodluck
Old May 6, 2004 | 09:43 PM
KayOs's Avatar
Use a tester and see if you blew a fuse.
Old May 6, 2004 | 09:44 PM
Built Beast's Avatar
Default Re: (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">Use a tester and see if you blew a fuse. </TD></TR></TABLE>
no need to use a tester to see if you blew a fuse...you look at the fuse and it the metal is broken in the middle it is broken.
Old May 7, 2004 | 03:15 PM
1sikcoupe's Avatar
yea i replace the fuse and works all good thanks 4 all the help guys
Old May 7, 2004 | 03:23 PM
labatia's Avatar
its ur fuse
Ricey McRicerton's Avatar
Default Re: cluster and tail lights blew!?!!! (labatia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatia &raquo;</TD></TR><TR><TD CLASS="quote">its ur fuse</TD></TR></TABLE>
No **** sherlock. He already fixed it. Keep up your bullshit and you'll be loosing points.
cleanda6
Oct 29, 2011 09:08 PM
looxs
11
Feb 5, 2007 04:06 PM
honda011
11
Aug 31, 2005 07:14 PM
mrbsponge
Dec 31, 2003 03:31 PM
smeister
May 24, 2002 04:09 PM
