question about better traction-60ft times
Old Nov 4, 2001 | 04:40 PM
speedworks's Avatar
Default question about better traction-60ft times
what are all the (serious) drag racers on this board doing for better traction.
already have 24.5x8x13 slicks and bogarts
accord rear springs
polyurethane kit in entire front end
bars from lower control arms to radiator support(like comp engineering)
front coil overs
occasionly have hit a 1.73 60ft. friends say i spin the first 60 ft.any ideas welcome
Old Nov 4, 2001 | 06:02 PM
Incognito's Avatar
Default Re: question about better traction-60ft times (speedworks)
Try the Skunk2 drag launch kit. I think they put soft sprongs in the front and like 900 pound rear springs. paul (FIxAlpha) has a set on his Civic and the launches feel great. The rear doesn't squat. If your car is full race, U can weld a stock shock so that there is no compression in the rear at all.
Old Nov 4, 2001 | 06:29 PM
earl's Avatar
9" wide tires and wheelie bars is all that you need as long as you are not getting any wheel hop.
Old Nov 4, 2001 | 06:30 PM
Rob03Pro5's Avatar
Default Re: question about better traction-60ft times (earl)
Stiffen up your motor mounts if you ARE getting wheel hop. Wheelie bar is a great item!
Old Nov 5, 2001 | 03:46 AM
speedworks's Avatar
Default Re: question about better traction-60ft times (Rob92SC)
wheel hop is not a problem. what about adjustable front shocks and front suspension limiters
Old Nov 5, 2001 | 10:14 AM
Incognito's Avatar
Also try the Z10 radius arms, or something like that. They can preload your front suspension.
Old Nov 5, 2001 | 10:28 AM
ekb18c's Avatar
Default Re: question about better traction-60ft times (Incognito)
z10 arms work great!
Old Nov 5, 2001 | 11:30 AM
b18bturbo's Avatar
i use the z10 radius arms and now after with 26*10 slick combo the car is hooking with 1.49 60ft times.
Old Nov 5, 2001 | 11:57 AM
Reverend's Avatar
Default Re: question about better traction-60ft times (b18bturbo)
Those look great, but do they fit with a JDM front end? All the pictures I've seen look like they bolt on to the radiator support somehow.
If they're all suspension and don't bolt to the frame, it would be gravy.
Old Nov 5, 2001 | 11:59 AM
b18bturbo's Avatar
Default Re: question about better traction-60ft times (Reverend)
it bolts to the factory tow hook locations i am not sure if JDM is difffernt by that much
Old Nov 6, 2001 | 05:01 AM
speedworks's Avatar
i have already made the equivelant of z10 bars. are you(b18bturbo) running a 1 peice front end and wheelie bars
Old Nov 6, 2001 | 07:09 AM
newsense's Avatar
New User
hey Ingonito.... those skunkworks you are referring to, are they full springs, or are they coilovers......
any idea what his 60fts are like?
Old Nov 6, 2001 | 07:28 AM
rtype11's Avatar
your short time is up there with the rear drive domestics, we have a vette that runs low 8 that hooks only 1.45!!!! you must be doing something very right! what does your car weigh???
Old Nov 6, 2001 | 09:26 AM
D-SPEED's Avatar
Default Re: question about better traction-60ft times (rtype11)
wow thats fast
Old Nov 6, 2001 | 11:34 AM
b18bturbo's Avatar
car is little runder 1980 in weight i think most classes gave us a 1900 stock weigh rating.
Old Nov 6, 2001 | 01:15 PM
Dublocivic's Avatar
GAWD.. 1.49's? thats crazy..
I have the z10s too.. great piece. hey b18b do you have solid mounts?
[Modified by Dublocivic, 10:16 PM 11/6/2001]
Old Nov 8, 2001 | 09:39 AM
Z10 Motorsports's Avatar
New User
Default Re: question about better traction-60ft times (Dublocivic)
hey whats up everyone, ill speak for the z10 bars that they do lower your 60ft times. and im not just saying that cause i work here im saying it cause of a some pro that uses them that loves them and a bunch of racers that love them more then their mothers. The product simply works, and thats that, would we make something that serves no purpose, now what fun would that be.. lol have fun guys
Old Nov 8, 2001 | 09:47 AM
b18bturbo's Avatar
Default Re: question about better traction-60ft times (Z10 Motorsports)
i love them they are so great after i upped the tire size and launching wit harder boost out of the hole.
Old Nov 8, 2001 | 09:50 AM
DIRep972's Avatar
Smarter than you
would these radius arms make much of a difference for a street car? street tires, regular street suspension, just like 10psi out of the hole? on regular pavement? or are they meant for mostly drag cars?
Old Nov 8, 2001 | 09:58 AM
Full-Race Geoff's Avatar
Default Re: question about better traction-60ft times (DIRep972)
they will actually make a huge difference on street cars, particularly if you get wheelhop when shifting hard into gear. They work equally well for a road course car as a drag car as turn in response is increased and control arm stability is dramatically improved.
If you get a chance, search the archives as many of the users of the kit are pretty happy with it. I personally use the arms on my turbo street car and have hit a 1.98 60 with 555r's. Obviously the 60s were better on slicks.
I havent had an opportunity to get some times on the new motor which will put down a bit more power, but i can assure you they work very well for a street car application. When we originally prototyped the bars we had the intention of making a product that can be bolted onto a street car and be "invisible" until you need to use them. This is apparent as during normal driving you cant feel them, but once you really get on it, the rock solid stability of the front end feels very secure. If you have any other quesitons email me at geoff@z10eng.com
Old Nov 8, 2001 | 10:03 AM
b18bturbo's Avatar
Default Re: question about better traction-60ft times (z10 geoff)
geoff how much preload can you really do off it. if preload any more will it make a difference.
Old Nov 8, 2001 | 10:06 AM
DIRep972's Avatar
Smarter than you
are 555r's drag radials?
Old Nov 8, 2001 | 10:13 AM
b18bturbo's Avatar
nt55r are drag radials from nitto
Old Nov 8, 2001 | 10:28 AM
Reverend's Avatar
is there still a group buy on the z10 radius arms?
Old Nov 8, 2001 | 02:17 PM
Hey Viren. The way i set them up on your car is probably the max you would want to go to. If you want to try to get some more negative caster, Roger Foo posted about swapping the Left and Right side upper control arms with one another. I think that will give you even more negative caster and allow you to launch even harder as it loads the suspension up on the launch. I am not 100% sure about what swapping the arms around will do exactly, but i know if anyone is gonna try it out, it will probably be you... Just an idea. Either way play around with the arms, Ive gone up to 5 turns and played around but i usually settle on 3. If you want me to, i can setup a pair of arms with you that are a little bit shorter so you can run crazy amounts of preload, but that would be a Drag only setup. Talk to you later
