About upgrading a Flywheel and a New clutch kit
Old May 6, 2004 | 05:52 PM
KeithGSR's Avatar
Default About upgrading a Flywheel and a New clutch kit
Hey, I was told by a friend of mine that the work I had done on my clutch would involve removing the turbo setup... at least by the housing, is this true???
Right now My car is with the dudes who installed my clutch....
ok, I had the ACT heavy duty pressure plate and the 6 puck clutch kit installed plus a 12lb flywheel. My car has the 18g turbo for a 99 gsr. WIll you be able to tell me if you have to mess with the turbo setup in order to install this clutch. ???
Old May 6, 2004 | 07:43 PM
tilt's Avatar
Default Re: About upgrading a Flywheel and a New clutch kit (KeithGSR)
the whole left side of the engine has to drop down. so the turbo needs to clear anything up front when it comes down.
Old May 6, 2004 | 08:23 PM
KeithGSR's Avatar
Default Re: About upgrading a Flywheel and a New clutch kit (tilt)
Im guessing that means the turbo would come down...Its in the front everything connects to the exhaust manifold. My mechanic that I had installed the clutch denied the fact of removing the turbo. Im told otherwise by another mechanic. Let me know any other details I could find useful.
Joeballz85
Feb 7, 2005 04:46 PM
jeffb006
Mar 14, 2004 04:33 PM
T3T495GSR
Jun 11, 2003 03:23 PM
Mugen Dom
Dec 2, 2001 09:36 PM
