is CTR 5lug same as USDM ITR 5lug???
Old May 6, 2004 | 04:38 PM
SPOON_BeIgHtEeNsEe's Avatar
Default is CTR 5lug same as USDM ITR 5lug???
i mean the alxe hole... cause i know the JDM ITR is bigger than the USDM ITR axles... but is the CTR the same as the JDM ITR or USDM ITR??? and when doing a 5 lug on a ek d series... i keep the stock LCA off the civic correct??? and if the axle holes are the same as USDM ITR, the d series axles will fit correct? or am i wrong? thanks
Old May 6, 2004 | 04:48 PM
t-blizzard's Avatar
Default Re: is CTR 5lug same as USDM ITR 5lug??? (SPOON_BeIgHtEeNsEe)
yes same size axles and what not.
but i dunno about the sohc axles
Old May 6, 2004 | 05:17 PM
EricUSC's Avatar
Default Re: is CTR 5lug same as USDM ITR 5lug??? (t.blizzard)
Both have same size axles and both will work with SOHC and DOHC engines. I think that the rear track of the CTR is wider than that of the USDM ITR. The JDM ITR rear track is wider than that of the CTR, but that swap would require that you either change the hubs or change the axles from 32 mm to 36 mm. There are no SOHC axles w/ 36 mm axles so the only way to use the JDM ITR 5 lug is to change the hubs.
Old Feb 12, 2006 | 11:13 PM
DC4KiD's Avatar
Default Re: is CTR 5lug same as USDM ITR 5lug??? (EricUSC)
Sorry for bringing up an old thread, but I didn't want to make another one.
My question:
If I were to get the CTR 5Lug conversion, will it directly fit my Integra (94+)? I'm pretty sure I can swap out my current 4lug and put the CTR 5lug on, but I just wanna make sure before i buy anything.
TIA
mark
Old Feb 13, 2006 | 12:25 AM
BlueIntegraBoy's Avatar
Default Re: is CTR 5lug same as USDM ITR 5lug??? (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for bringing up an old thread, but I didn't want to make another one.
My question:
TIA
mark</TD></TR></TABLE>
Yup
Old Feb 13, 2006 | 01:37 PM
DC4KiD's Avatar
Default Re: is CTR 5lug same as USDM ITR 5lug??? (BlueIntegraBoy)
thanks again bro!
Old Feb 13, 2006 | 02:24 PM
1SIKEG6's Avatar
will usdm itr 5lug fit my eg with a soch motor ?? or do i have to modify my axles
Old Feb 13, 2006 | 02:46 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (1SIKEG6)
yes, all US civic/tegs take a 32mm axle inlet.
Too_slow_eg
Suspension & Brakes
16
May 7, 2009 10:58 PM
em12nv
Feb 2, 2008 06:36 PM
ekeddie
Texas -OK -LA (Sales)
Oct 20, 2007 02:11 PM
jdmjohn02
Jan 12, 2004 12:03 AM
