Timing belts: Greddy or Toda
Old May 6, 2004 | 03:18 PM
SupaFly_Honda's Avatar
Default Timing belts: Greddy or Toda
I'm in the market for a new performance timing belt but I don't know which one is better. I read alot about the toda belt but didnt' get much about the Greddy. Are they both equal in quality?
Old May 6, 2004 | 03:32 PM
Grip's Avatar
Default Re: Timing belts: Greddy or Toda (SupaFly_Honda)
i have the toda for the bling..everyone says oem is the best
Old May 6, 2004 | 04:42 PM
Drag_Racer_DRU's Avatar
Default Re: Timing belts: Greddy or Toda (Grip)
stock the toda one is cool cuz its Red
Old May 6, 2004 | 05:26 PM
jdmcx's Avatar
Default Re: Timing belts: Greddy or Toda (Drag_Racer_DRU)
aren't they all the same greddy toda and power extreem????????
Old May 6, 2004 | 09:12 PM
Solo2Vtec's Avatar
Default Re: Timing belts: Greddy or Toda (jdmcx)
HOWABOUT STOCK??!! HAS A GOOD CONDITION STOCK ONE EVER BROKE..? NO.
Old May 6, 2004 | 09:25 PM
Broken Gearbox's Avatar
Default Re: Timing belts: Greddy or Toda (Solo2Vtec)
Ehh...i hear there a waste of money. Stick with OEM.
Old May 6, 2004 | 09:38 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2Vtec &raquo;</TD></TR><TR><TD CLASS="quote">HOWABOUT STOCK??!! HAS A GOOD CONDITION STOCK ONE EVER BROKE..? NO.</TD></TR></TABLE>
and you know this?
I dont think so.
Old May 6, 2004 | 09:51 PM
b19coupe's Avatar
All timing belts, if improperly tensioned, will fail. The PE/Toda belts are nice, and nothing wrong with the OEM belt either.
Old May 6, 2004 | 11:08 PM
All Toda Dc2
Guest
Posts: n/a
Default Re: Timing belts: Greddy or Toda (b19coupe)
A wise & experienced engine builder once told me.. always buy the best timing belt possible.
Old May 7, 2004 | 04:53 AM
theres alot of cams/ headers/ and exhaust challenges. Has anyone ever done a timing belt challenge to see which one can hold more? I think this would be a good idea
Old May 7, 2004 | 08:36 AM
EEK's Avatar
EEK
the toda timing belt is suppose to be 200% stronger than stock...so i would assume its better than oem
Old May 7, 2004 | 08:53 AM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">All timing belts, if improperly tensioned, will fail. The PE/Toda belts are nice, and nothing wrong with the OEM belt either.</TD></TR></TABLE>
exactly! id rather buy an oem one for 50-60 bucks and change it twice as often.
Old May 7, 2004 | 01:18 PM
DefiantGSR's Avatar
Default Re: Timing belts: Greddy or Toda (ArinX)
Toda belts need to be used with toda b and up cams if im not mistaken. They have a tendancy to shred OEM belts up.
"you guys have never installed a set of Toda cams and degreed them. If you had, you would know exactly what I mean when you turn the crank manually with these cams: they load the belt (harder to turn the crank) as you approach max. lift or the nose of the cam. This binds the belt if the belt has any slack in it whatsoever and the tensioner hasn't taken up the slack. So to prevent this, you add more tension to the belt. That extra tension is way too much for the stock belt at 5000 rpm and up. " -Michael Delaney
Old May 7, 2004 | 02:05 PM
BERT-O's Avatar
I have a spare brand new PE t-belt for BVTEC motors for sale.
$125 shipped,
Bert
Old May 7, 2004 | 04:20 PM
TodaSi's Avatar
Default Re: Timing belts: Greddy or Toda (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">Toda belts need to be used with toda b and up cams if im not mistaken. They have a tendancy to shred OEM belts up.
"you guys have never installed a set of Toda cams and degreed them. If you had, you would know exactly what I mean when you turn the crank manually with these cams: they load the belt (harder to turn the crank) as you approach max. lift or the nose of the cam. This binds the belt if the belt has any slack in it whatsoever and the tensioner hasn't taken up the slack. So to prevent this, you add more tension to the belt. That extra tension is way too much for the stock belt at 5000 rpm and up. " -Michael Delaney</TD></TR></TABLE>
Yep, yep. For Toda B or C cams always run a PE or Toda belt, I ran a stock belt and it lasted only 18,000 miles, then all my intake valves were bent. You decide.
Old May 7, 2004 | 05:09 PM
DefiantGSR's Avatar
Default Re: Timing belts: Greddy or Toda (TodaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, yep. For Toda B or C cams always run a PE or Toda belt, I ran a stock belt and it lasted only 18,000 miles, then all my intake valves were bent. You decide.</TD></TR></TABLE>
Tuan's aka micheal delaney's belt didn't even last long enough for his break in. lol
Old May 7, 2004 | 06:59 PM
SuperTwinz's Avatar
Greddy and Toda timing belts are made by Power Enterprise for your info.
Old May 7, 2004 | 08:02 PM
Default Re: Timing belts: Greddy or Toda (SuperTwinz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz &raquo;</TD></TR><TR><TD CLASS="quote">Greddy and Toda timing belts are made by Power Enterprise for your info. </TD></TR></TABLE>
thanks for the info
Old Oct 14, 2004 | 03:36 PM
UnKnownUser's Avatar
Hey im thining about greedys belt but what would you use for 9500rpms?What are you guys saying about it be tensioned?
Old Oct 14, 2004 | 03:44 PM
K-Drum's Avatar
where is a good place to buy a PE t-belt ?
Old Oct 14, 2004 | 03:51 PM
JerseySiPOS's Avatar
Default Re: Timing belts: Greddy or Toda (LSVTEC DC4)
i have a toda belt with my toda cams. id be afraid to use the oem belt although many ppl do with aftermarket cams.
i bought the belt as cheap insurance.
Old Oct 14, 2004 | 04:53 PM
rodrez.'s Avatar
It happens all the time, just do a search.
HondaIntegraR
Mar 25, 2005 12:51 PM
43MA
Dec 16, 2004 11:56 PM
Jowee
Nov 12, 2004 02:09 PM
jdmitr98
Feb 25, 2003 10:51 PM
