problems with tokico blues and H&R sports
Old May 6, 2004 | 01:51 PM
civboy115's Avatar
Default problems with tokico blues and H&R sports
I am having a problem with my H&R sport springs and my tokico blue struts. On my 98 civic EX, there is a horrible thudd thudd sound every time i go over a bump. Small or large...doesnt matter. It sounds so bad. The noise is worse since my trunk is gutted...but i just wanted to know if i need to cut the bumpstops? or what...i have heard alittle about cutting the bumpstops...and wonder if that will help.
It just sounds like something is rickety as hell back there. it only happens in the back, and the front rides perfectly fine. Other than that perablah, i like the combo.
any help guys? thanks.
Old May 6, 2004 | 02:16 PM
FcUK It.'s Avatar
it sounds like you're bottoming out. if you didn't cut the bumpstops, that might be the problem, you need to cut them in half when lowering your car. try that
Old May 6, 2004 | 02:31 PM
civboy115's Avatar
Default Re: (frosteg6)
i know im not bottoming out. my cars only lowered 1.8 max...or do u mean bottoming out in some other way? please explain....
Old May 6, 2004 | 02:36 PM
FcUK It.'s Avatar
Bump stops could be too long, especially stock hard rubber ones that can steal 2 or 3 inches of travel. Bump stops should benefit the car, not make it worse.
taken from http://www.ground-control.com/...d1fa8
Old May 6, 2004 | 02:40 PM
civboy115's Avatar
i checked out the site and that perticular info is for front suspensuion....this is happening to me in the back. would it be a different situatuion or similar>
Old May 7, 2004 | 09:33 AM
undertheradar's Avatar
Default Re: (civboy115)
Yes you need to cut your bumpstops. By bottoming out, he meant that the shock can only compress so far before they hit the bumpstops. Thats probably the clunking you hear.
Old May 7, 2004 | 12:52 PM
civboy115's Avatar
Default Re: (undertheradar)
oh ok, thanks man.
SwiftTypeR
Apr 9, 2007 10:38 PM
LvN
Suspension & Brakes
Apr 22, 2006 03:52 PM
civboy115
Aug 20, 2004 09:27 AM
stilzx61
Jan 19, 2004 06:30 PM
gumbybum
Apr 11, 2003 08:17 AM
