4 sale full race motor for your car?
Old May 6, 2004 | 01:12 PM
12SecHatch's Avatar
Default 4 sale full race motor for your car?
make reasonable offers on trades, cars only
Engine block prep. New GEN 3 block prep $795.00
Hot tank and clean yes included in gen 3
Step deck yes .0035 included in gen 3
Resleeve Yes Highest quality ductile iron included in gen 3
Bore cylinders 84mm included in gen 3
Power hone Yes, finished with sunnen AN300 stones included in gen 3
Deck block surface Yes, micro finish included in gen 3
Micropolish crank yes $50.00
Balance Yes, ultra balanced $150.00
Main bearings Yes, using hand lapped oe bearings $90.00
Rod bearings Yes, using hand lapped oe bearings $75.00
Thrust bearings yes $20.00
Oil pump TypeR with toda gear $300.00
Seals and gaskets yes $100.00
Oil pan cleaned
Con rods ESP turbo rod with custom age rod bolts $460.00
Pistons JE $460.00
Piston size 84mm
Comp ratio 9.0
Ring pack JE $110.00
Head studs ARP $140.00
Head gasket Cometic HP turbo $95.00
Timing belt New belt $65.00
Cam gears JG billet $150.00
Camshafts JG 296 300 cams ground on new cores $750.00
Cylinder head Full race. The very best we have
Port work Full competition port and polish $750.00
Intake valve guides Tapered $40.00
Exhaust valve guides Tapered down
Valve spring retainers Titanium 6AL4V $130.00
Valve springs JG dual $220.00
Valve job Full radius intake and 3 angle exhaust $150.00
Intake valve seats JG oversize custom seats $160.00
Intake valves Stainless steel 35mm $120.00
Exhaust valves Stainless steel 28.5mm $120.00
Valve seals New $20.00
Chambers Polished
Cleaning Hot tanked $20.00
Blue print and assemble engine, set all clearances $950.00
Total for engine $6,490.00 plus tax and shipping
after tax $7250 for motor plus shipping and core gsr long block $2000 for gsr long block
so total on this motor was spent $9250 plus shipping on 2 long blocks
89B16Civic
44
Jan 28, 2006 09:50 PM
12SecHatch
Aug 7, 2004 02:46 PM
12SecHatch
Jun 26, 2004 08:52 PM
Saltine Box Racer
Apr 14, 2003 12:15 PM
3rdGteg
Sep 27, 2002 05:56 AM
