Idle acting up help?
Wutz up guys, my idle is acting funny, whenever I come to a complete stop the idle needle gets stuck on 2000 to 1200 rpm, so I Have to rev it a little to get it back to normal. I don't know what it can be?
this has been cover so many times. try searching next time. could be a vacuum leak, tps, iac, air in the cooling system, (but then it would be running hot too), some people even had O2 sensors cause this problem
sounds like a minor vacuum leak near ur throttle body or your tps acting up anyways u really cant by u just telling us the problem i can tell u this if u have a idle speed adjuster dont touch it should be factory set
