ITB throttle bores
Old May 6, 2004 | 11:34 AM
taildragger's Avatar
Default ITB throttle bores
What size throttle bores are you guys running on ITB's for a b sereis?
Old May 6, 2004 | 04:15 PM
blazin's Avatar
Default Re: ITB throttle bores (taildragger)
Most common 42-50mm.
Old May 23, 2004 | 04:46 PM
Circuit Star-29's Avatar
Default Re: ITB throttle bores (blazin)
I'm running (about to be anyway) 42mm 954s.
Modified by nathan atwell at 11:20 AM 5/24/2004
Old May 23, 2004 | 05:39 PM
meanEG's Avatar
Default Re: ITB throttle bores (nathan atwell)
h22 = 50mm
Old May 24, 2004 | 09:49 AM
Kendall's Avatar
We're running 42mm throttle bodies and are very pleased. If you want more power, look at fuel atomization and air velocity rather than throttle body size. The JGTC NSX's run with a single 41mm throttle body.
Old May 24, 2004 | 10:48 AM
MiKE 76...
Guest
Posts: n/a
Default Re: (Kendall)
48mm here.
As for what kendall said about fuel atomization, the guys who are taking up the "DIY ITB's" projects should consider this. It seems everyone is doing it, but stilll keeping the stock injector placement.
fg2si!kid
Acura TL, RL & ZDX
Jun 26, 2008 03:57 PM
LU
Nov 10, 2006 10:54 PM
Don Jefe
Dec 24, 2005 11:31 AM
CRXRageD
Apr 19, 2002 08:48 AM
93H22A
Dec 6, 2001 12:15 AM
