Insane List:Sensors, bare block, z6 crank Trade for turbo parts
2 D/B series speed sensor ($40 each)
Stabilizer section of gsr linkage with shifter still attached ($45)
3 sets D series axels ($110 a set)
d16z6 crank ($best offer)
Bare d16z6 block w/ main caps only (best offer)
3 4 wire o2 sensor ($45 each)
GSr injectors (240cc great for d series guys) ($45)
bare b16 thottle body ($60)
95 Integra headlights (a little cloudy) Best offer
95 GSr cruise control brain w/ cable
z6 flywheel (prob needs a light resurface) ($20)
Driver side upper mount (chassis part only) ($40)
97 GS-R 4 door tan cloth insert door panals (fronts have tweaters)
2 USDM GSR valve covers (7.5 of 10 looks) ($60)
1 Chromolusion 93 GSR valve cover (8 out of 10) ($75)
Stock 98 GSR springs ($40)
JDM GSR OEM exhuast manifold (1994) ($35) (has flexpipe welded, so cant bolt cat on)
2 Bare GSR intake manifold ($30 each)
Bare 95 LS throttle body ($40)
2 Chassis mounted map sensors ($10 each)
95 CX cluster ($15)
95 cx computer ($20)
GSR power mirrors (dark green)
95 GSR exhuast manifold ($35)
B series Ac compressor only
B series power steering pump
Things needed, tial 35/38 w/ at least 9psi spring, Safc, Cd player
95 CX cluster ($15)
Phaze2 Mike
Feb 14, 2004 09:05 PM
