d16 clutch
Old May 6, 2004 | 02:56 AM
J-Spec EG's Avatar
Default d16 clutch
Ona stock D16z6, ie the one i have in my civic. If i wanted to change the clutch would there be enough clearance to just drop the tranny instead of the motor, all i would do is unbolt all the transmission bolts and disconnect axles and then continue to disconnect any other misc **** such as the ground and things like that. Then set a jack under the transmissionand set it down then do the exact opposite and i should be good right? Let me know if im distorted about anything.
Old May 6, 2004 | 03:18 AM
Chiovnidca's Avatar
Default Re: d16 clutch (J-Spec EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Spec EG &raquo;</TD></TR><TR><TD CLASS="quote">Ona stock D16z6, ie the one i have in my civic. If i wanted to change the clutch would there be enough clearance to just drop the tranny instead of the motor, </TD></TR></TABLE>
That's the way I usually do them.
Old May 6, 2004 | 04:45 AM
Jimmy's Avatar
Global Moderator
Sounds like you had it right.. and also searching will help ALOT.
Here you go:
https://honda-tech.com/zerothread?id=811691
slammeda
Feb 11, 2010 02:46 AM
crxricer66
Nov 14, 2007 03:15 PM
wfocrx
Sep 20, 2007 02:10 AM
chillax
Aug 25, 2003 04:00 PM
