15.2 @ 92 MPH in my del sol
Old May 5, 2004 | 10:02 PM
AzntaggeR's Avatar
TSPeed Factory
Default 15.2 @ 92 MPH in my del sol
finally got a chance to run my car after the swap
R/T................... .453
60'.................... 2.438
330................... 6.571
1/8................... 9.898
MPH.................. 73.56 MPH
1000................. 12.765
1/4................... 15.207
MPH.................. 92.07 MPH
Here is a pic and list of my mods:
H-T Garage
i'm quite disappointed. i was really aiming for 14s. my 60' times were shitty.
i'm going again this friday and i'm determined to break into the 14s.
Old May 5, 2004 | 10:04 PM
STREETWERKZ's Avatar
Default Re: 15.2 @ 92 MPH in my del sol (AzntaggeR)
totally NOT impressed.
there is a girl i know that is running high 14s with a STOCK LS motor with bolt ons in an EG hatch.
i say you need more saet time.
Old May 5, 2004 | 10:06 PM
TegBen's Avatar
dont worry man, if the motor is good, you probbaly just need some good old tuning, or you just cant drive . . . . either way you car should be running faster than a 15.2
au revoir and good luck to ya!
Old May 5, 2004 | 10:17 PM
WhiteEG6's Avatar
92 MPH is a pretty high MPH for a 15.2. With that MPH your making enough power to get mid to high 14's. Either you need better tires or seat time.
Old May 5, 2004 | 10:21 PM
cliff666's Avatar
Default Re: (WhiteEG6)
u can hit 14.7s wit that setup possibly. but a gsr too???? that seems kinda low for MPH for even a GSR swap my freind's EK hatch that weighed in at like 2500 went 14.4@96 with just i/h/e/skunk2 IM but wit that time u should be 14.7s def but u gotta cut a nice 2.2 60' if u pull a 2.1 ull be mid low 14s
Old May 5, 2004 | 10:37 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (bruceHungLO)
you guys think so? i think so too. my friend with an EK ran a 14.4 @ 94 mph. i think my launches are what's killing me. i even let some air out of the tires.
Old May 5, 2004 | 11:11 PM
Tad's Avatar
Tad
dang man.
well it is a sol so its kinda heavy
2340 is going to hurt times, but its not THAT heavy.
you should definetely be in the 14's...
thos launches are pretty bad.
why dont you find a safe abandoned road somewhere and just practice some launches?
make sure its realy wide and no ones ever around , dont wana c u fukin urself or others up of course.
it'll take more than letting air out of the tires to launch well man , fwd is a toughie off the line.
Try and fine what is your optimal rpm to launch at, and practice not just dumping it and letting your tires spin allover the place
Old May 5, 2004 | 11:25 PM
Ski11z's Avatar
Default Re: (Tad)
Ran 14.8 with a 00 GSR in a EG, all stock internals, stock i/h/e. That was before my motor got stolen
Old May 6, 2004 | 01:32 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (Ski11z)
i'm aiming for 14.7 on friday. here's my plan:
run seafoam through my motor
change oil
change spark plugs and wires
wire up my IABs or just get my secondaries to stay permanently open
rotate the tires
try to reduce even more weight
run my rechipped P28 as well as an obd-1 P72
practice some more launching
run open header (this is a maybe)
i heard the IABs being closed is really hurting my top end.
Old May 6, 2004 | 02:38 AM
Eg Smurf's Avatar
I don't want to say anyhting but where are you luanching at? Also with that motor and you hit 15.2. Even with the tuning sorry to say it must be the driver. Practice more and you'll do wonders. Practice luanching at 5k then 500 plus after eveytime you get it down.
Old May 6, 2004 | 05:01 AM
Jimmy's Avatar
Global Moderator
Reading your mods in your h-t garage..
It seems you only have 2 mods that's helping you HP wise.. (short ram intake & vafc if tuned)
Get you a nice header and nice exhaust setup and get your vafc dyno tuned and you'll run mid 14's / low 14's all day.
Goodluck
Old May 6, 2004 | 05:34 AM
EdLeake's Avatar
What do you Americans runk, standing quarter miles?
To give you an idea a Civic Type R would be getting 14.5-15 seconds on a UK drag (1/4 mile).
Old May 6, 2004 | 05:52 AM
Phil DeVtec's Avatar
Default Re: (EdLeake)
def. need a better 60'. 2.4 is not gonna cut it.
skip.two's Avatar
its okay AzntaggeR. just work those 60ft's. you'll get into your 14's.
Old May 6, 2004 | 06:08 AM
Louie_EM1
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote">92 MPH is a pretty high MPH for a 15.2. With that MPH your making enough power to get mid to high 14's.</TD></TR></TABLE>
You're either trying to make him feel better or you're simply taking out of your ***.
I'm not going to lie to you, those numbers are horrible with a c1; and not to mention you got a nice set-up.
I notice you have a VAFC - Are you tuned, with a dyno?
I think you know what to do, pactice the launches, get some better front tires, lower the psi and keep trying.
Old May 6, 2004 | 06:58 AM
Xander teh Grate!'s Avatar
Default Re: (Louie_EM1)
Yikes, glad I invested in a turbo instead of a B series.
Old May 6, 2004 | 07:13 AM
cliff666's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">dang man.
Try and fine what is your optimal rpm to launch at, and practice not just dumping it and letting your tires spin allover the place</TD></TR></TABLE>
thats actually kinda light my car weighs in at 2420 with me in it and with a straight b20z w/ ls tranny (no vtec) runs a best of 14.4@94mph its all on ur 60's tryin slipping the clutch out instead of droping the hammer until the clutch is all the way out. thas how i pulled a 2.108 60' on street tires
Old May 6, 2004 | 07:48 AM
1hotcivicSi's Avatar
wow i thought it was a b16 i was gunna say nice time but GSR???? wow dude not impressed at all
Old May 6, 2004 | 07:55 AM
Todapwr's Avatar
Default Re: 15.2 @ 92 MPH in my del sol (1hotcivicSi)
OK i can see ur hitting 14's u need to bring down ur 60's foot time i ran a 14.3 in my EG hatch w/b16 w/i/h/e
Old May 6, 2004 | 08:06 AM
bluebird's Avatar
What tire combo are you running????I had SI 15" Bf goodrich Drag radials B20Z stock with stock GSR head and it turned 14.1 at 99 at Palmdale...(high Elevation )
Old May 6, 2004 | 08:17 AM
daver's Avatar
Default Re: (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">
i heard the IABs being closed is really hurting my top end.</TD></TR></TABLE>
no, if your IAB isn't wired, then the butterflies default open.
Your 60' time is awful tho, you must launch like me. The 92mph looks a little weak too; are you using the stock cat?
d
Old May 6, 2004 | 08:24 AM
todaspecsi's Avatar
Hey bro dont worry bout it... I know how ya feel. I have a 99si with a toda valve train and was completely disappointed... 15.4 @95mph
https://honda-tech.com/zero...age=1
We just need more practice at the track. That was my first time ever there and had a 2.6 60'
Old May 6, 2004 | 08:25 AM
DC2EGHB's Avatar
Default Re: (daver)
Yeah you need to work on your launch, and you'll get better times for sure. I ran a 15.0@90....2.1 60'....LS w/ I/H/E full interior and system.
Old May 6, 2004 | 08:26 AM
todaspecsi's Avatar
Default Re: (DC2EGHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2EGHB &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you need to work on your launch, and you'll get better times for sure. I ran a 15.0@90....2.1 60'....LS w/ I/H/E full interior and system.</TD></TR></TABLE>
haha you just gave me up for better times.. lol thanks bro. How do ya get your 60' so low?
Old May 6, 2004 | 08:40 AM
sean's Avatar
Default Re: (todaspecsi)
you definately have the mph for 14's. my friends ek went 14.6 with a b20 @ 92 mph. just cut your 60 foot down and you're set. also i wouldnt run a chipped p28 with the stock gsr mani, but thats just me.
