b20z/vtec
Old May 5, 2004 | 08:38 PM
JBk24crx's Avatar
Default b20z/vtec
im building a b20/vtec and i need advice tru out the set up.
b20z2 block (stock pistons)
b16 head
itr cams
2layer h.g
arp head studs rod bolts.
Old May 5, 2004 | 09:58 PM
DefiantGSR's Avatar
Default Re: b20z/vtec (JBLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">im building a b20/vtec and i need advice tru out the set up.
b16 head
itr cams
2layer h.g
arp head studs rod bolts.</TD></TR></TABLE>
what exactly do you need to know? lol
Old May 5, 2004 | 11:06 PM
H2nr's Avatar
if your doing stock pistons use a stock heagasket
Old May 6, 2004 | 05:34 PM
JBk24crx's Avatar
Default Re: b20z/vtec (DefiantGSR)
I would like to know if with the stock b20z pistons, 2 layer headgasket and ITR cams is there any clearance issues with the stock b20z pistons.
Old May 6, 2004 | 05:48 PM
nickgmiller04's Avatar
i wouldnt think so..since the stock pistons are like 8.xx or low 9.xx CR. but i dont know for sure.
Old May 6, 2004 | 05:53 PM
slowazzhatch's Avatar
Default Re: b20z/vtec (nickgmiller04)
b20z pistons...head milled ".020...toda b's...no problem
i myself have a b20b block, .020 milled off my head, stock b16a cams, 2 layer headgasket, no problem, i am putting in PHK pistons in about 2 weeks, then going back to a stock headgasket and going with an ITR valve train
i say use a STOCK head gasket, and you should be fine
Old May 6, 2004 | 09:12 PM
Solo2Vtec's Avatar
Default Re: b20z/vtec (slowazzhatch)
you need to make bigger valve reliefs for the bigger vtec valves.
Old May 10, 2004 | 01:46 PM
H2nr's Avatar
Default Re: b20z/vtec (Solo2Vtec)
I did a B20zVtec for my best friend in his 94 teg. Stock B20z block, pistons, crank, and rods. With a stock GSR head, cams, and the stock mani ported. Stock B20 head gasket, no milling, or grinding on the pistons. Stock GSR ECU with a VAFC. The car is his daily driver, AC, power steering, full interior...........and it runs 13.9s in the 1/4. I am not a fan of milling or two layer gaskets.
fohdoteggy
Feb 29, 2012 02:36 PM
Hamstr323
15
Jun 16, 2005 03:14 PM
B16Hatchcx
May 3, 2004 08:08 PM
vivid02
10
Jun 5, 2003 07:33 AM
