Front Brakes Seized up...Advice please.
I just did a legend dual pistons set up on my del sol. Everything went on smoothly. After bleeding both front brakes....I went to test to see if I can spin the wheels freely, but it seemed like they are seized up. I cant spin them. Like someone is stepping on the brake. I thought it was normal..then I took it for a ride...as soon as i let go the gas pedal..it would stop like i'm braking, but I'm not. It's almost like riding with E-brake on. The clearance of the calipers and the rotors have been checked..no contact. Bleeded the two front brakes only...didn't do the entire system. Not sure if that could be the problem.
Any input is appreciated. Thanks in advance.
By any chance did you forget to shave the calipers? They will not fit exactly and require some shaving until they fit properly....I read a thread about it...gimme a sec
---edit---
voila
http://www.gs-r.com/phpBB2/viewtopic.php?t=5477
---edit---
voila
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostin'RPS13 »</TD></TR><TR><TD CLASS="quote">caliper(s) may need a rebuild.</TD></TR></TABLE>
Right on the money!
Got a replacement...and it's smooth like butter.
Right on the money!
Pickelz10
10
Jun 3, 2013 06:10 PM
wicked2night
Jan 2, 2007 06:36 PM
idriveadelsol7
Jul 30, 2005 09:36 AM
