HX wheels on teg?
Old May 5, 2004 | 05:43 PM
simplegreenmachine's Avatar
Default HX wheels on teg?
Will HX wheels fit on an integra LS? i heard you can use spacers but i wanted to know. Anyone have pics? i searched.
Old May 5, 2004 | 06:31 PM
Default Re: HX wheels on teg? (MonKey Magic)
BUMP
Old May 5, 2004 | 06:33 PM
LSTEG96's Avatar
dont bump this bullshit... you couldve searched by now and clearly figured it out.
Old May 5, 2004 | 06:50 PM
b20vtecv8killer's Avatar
HX WHEELS ARE 13 INCHES I THINK THEY WILL FIT ONLY ON THE REAR BUT THE FRONT WON'T FIT THEY ARE VERY LIGHT I THINK 11 POUNDS??
LET ME KNOW IF YOU FIND OUT , I LIKE LIGHT WHEELS RIGHT NOW I HAVE A SET OF BLADES BUT THEY WAY LIKE 15.6 LBS OR SOETHING LIKETHAT
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonKey Magic &raquo;</TD></TR><TR><TD CLASS="quote">Will HX wheels fit on an integra LS? i heard you can use spacers but i wanted to know. Anyone have pics? i searched. </TD></TR></TABLE>
You have almost 2k posts, and you said you searched, but how do you not know this??
it was covered many a time on here before.
But, since I came here to rant and rave, I might as well spoon feed you the answer too.
They will not fit without a spacer. The 14" wheels won't clear the LS caliper. You COULD grind the caliper down, but I don't recommend it.
Old May 5, 2004 | 06:52 PM
Default Re: HX wheels on teg? (INEEDGSRTRANNY-2145003960)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INEEDGSRTRANNY-2145003960 &raquo;</TD></TR><TR><TD CLASS="quote">HX WHEELS ARE 13 INCHES I THINK THEY WILL FIT ONLY ON THE REAR BUT THE FRONT WON'T FIT THEY ARE VERY LIGHT I THINK 11 POUNDS??
LET ME KNOW IF YOU FIND OUT , I LIKE LIGHT WHEELS RIGHT NOW I HAVE A SET OF BLADES BUT THEY WAY LIKE 15.6 LBS OR SOETHING LIKETHAT</TD></TR></TABLE>
1. turn the caps lock off. That's annoying as hell.
2. the size of the wheel does NOT determine it's weight. I have 15" wheels that weigh in under 12 lbs. They make 17" wheels that weigh 12 lbs.
Old May 5, 2004 | 06:54 PM
gundamgsr's Avatar
my heliums are 10.5 lbs.
Old May 5, 2004 | 06:58 PM
Default Re: HX wheels on teg? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
They will not fit without a spacer. The 14" wheels won't clear the LS caliper. You COULD grind the caliper down, but I don't recommend it.</TD></TR></TABLE>
thanks all i wanted to know.
Old May 5, 2004 | 08:02 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: HX wheels on teg? (EGGSAUCE)
wow after all the bullshit in this thread and nobody just gave him the clear n simple answer? even 1 clown gave him completely wrong info saying they were 13"
the hx's are 14" and WILL fit with wheel spacers available at your local rim shop. you only need them for the front brakes, the rears fit fine!
good luck
sixtodc4
Aug 17, 2008 11:03 AM
JapanExpress
Jan 5, 2005 08:28 PM
Chris_Bye
Dec 23, 2004 06:21 AM
kevinm1981
Dec 14, 2002 10:26 AM
Chip398193
Jul 25, 2001 11:35 AM
