Parting out D16Z6 Swap, Motegi MR7s, Precision SC34, '96 Integra Misc Motor Parts
All D-Series items below are off of a 93 del Sol Si D16Z6
-Motor (Possibly to be parted out)
-Transmission $175
-Axles $50
-Shift Linkage
-Shifter
-Flywheel
-Clutch
-Wiring Harness $100
-P28 ECU SOLD
-Distributor $80
-Alternator
-Starter $50
-Intake Manifold
-Throttle Body
Picture Unavailable
-Fuel Rail
-Injectors
-Exhaust Manifold (Upper and/or Lower)
-Fuel Pressure Regulator
-VTEC Solenoid
-Power Steering Pump
-Power Steering Belt
-Power Steering Reservoir
-Intake Manifold Support
-Exhaust Manifold Support
-Exhaust Manifold Heat Shield
-Alternator Brackets
-Miscellaneous Bolts
<U>Sensors</U>
-MAP
-VSS
-IAT
-O2 (If I can get the sucker out without breaking it)
Complete Air Conditioning System out of 1993 del Sol Si
- Missing only the AC Belt $250 OBO
http://home.comcast.net/~dkettler85/AC2.JPG
http://home.comcast.net/~dkettler85/AC3.JPG
<U>Parts off of '96 Integra LS w/ 12,880 miles</U>
- Injectors
http://home.comcast.net/~dkettler85/Injectors.JPG
- Power Steering Bracket (P54)
http://home.comcast.net/~dkettler85/PSBracket.JPG
- Drive Plate (with washer/AT bolts)
- Thermostat Housing & Connecting Pipe
- Exhaust Manifold (Upper only)
- Alternator Brackets
- Intake Manifold Support
http://home.comcast.net/~dkettler85/lsparts1.JPG
<U>B20 Parts</U>
- Timing Belt 512 miles for B20/B18B (OEM) 125RU26
http://home.comcast.net/~dkettler85/TimingBelt.JPG
- Alternator Belt
- Power Steering Belt
http://home.comcast.net/~dkettler85/Belts.JPG
- OEM Front & Rear Rotors off of a 1993 del Sol Si - 110k miles $25
Modified by Aber at 3:12 PM 6/13/2004
Modified by Aber at 1:07 AM 6/19/2004
-Transmission $175
-Axles $50
-Shift Linkage
-Shifter
-Flywheel
-Clutch
-P28 ECU SOLD
-Distributor $80
-Alternator
-Starter $50
-Intake Manifold
-Throttle Body
Picture Unavailable
-Fuel Rail
-Injectors
-VTEC Solenoid
<U>Sensors</U>
-MAP
-VSS
-IAT
- Injectors
<U>B20 Parts</U>
- Alternator Belt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mighty »</TD></TR><TR><TD CLASS="quote">Would you happen to have the hydraulic clutch piping for the LS?</TD></TR></TABLE>
I do not have the clutch piping.
I need the Throttle cable bracket from the intake manifold and the Heat shield off the exhaust manifold. How much shipped to Roanoke VA 24019? LMK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncivical »</TD></TR><TR><TD CLASS="quote">Where are you located? And PM sent.</TD></TR></TABLE>
I'm in Indiana.
I'm in Indiana.
From: hittin corners so hard you can taste my rims..
where are you located.. im interested in the tranny.. but i'll take the whole motor if the deals right... also.. the AC compressor if it could be seperated... location though, ide like to grab the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">where are you located.. im interested in the tranny.. but i'll take the whole motor if the deals right... also.. the AC compressor if it could be seperated... location though, ide like to grab the engine.</TD></TR></TABLE>
I'm in Indiana. I'll part out the Power Steering, but going to keep the Air Conditioning setup as a whole system. Feel free to make offers on anything.
