99 Civic SI - Transmission Mainshaft Bearing - Replacement
Old May 5, 2004 | 01:27 PM
Splork2000's Avatar
Default 99 Civic SI - Transmission Mainshaft Bearing - Replacement
Also posted in Civics. Please forgive if this is the wrong place for this question.
I have to replace the mainshaft bearing on my 99 SI Transmission. My question is: does this transmission come apart easily, i.e. undo the casing bolts, remove the freeze plug type cover and undo the circlip?
Any help or insight with regard to this job will be appreciated.
Thanks.
Old May 5, 2004 | 02:43 PM
acy76's Avatar
Default Re: 99 Civic SI - Transmission Mainshaft Bearing - Replacement (Splork2000)
I wouldn't open a transmission without the service manual. There are too many parts that could be installed incorrectly by mistake, as well as clearances that need to be checked etc. Opening it up is fairly straightforward, but read the manual to see what you're getting into.
TeeO
Oct 17, 2012 08:29 AM
snouka
Mar 30, 2005 01:35 PM
