Head gasket for turbo B18C?????
Old Nov 4, 2001 | 06:38 AM
01-0338R's Avatar
Default Head gasket for turbo B18C?????
Can anyone recomend a head gasket other than oem for a turbo B18C for 20 lbs of boost or more? Thanks
Old Nov 4, 2001 | 06:44 AM
b18bturbo's Avatar
Default Re: Head gasket for turbo B18C????? (JDMkoupe)
OEM is the way togo. But if you looking for a little bit better than oem go with either HKS or full copper with oring on the block.
Old Nov 4, 2001 | 04:39 PM
Jared's Avatar
Default Re: Head gasket for turbo B18C????? (dc2jdmhonda)
Inline pro gaskets are simply stock gaskets with a thick copper center piece. sealing properties still same as a stock gasket.
Old Nov 4, 2001 | 05:26 PM
falcongsr's Avatar
What is this crap?
Default Re: Head gasket for turbo B18C????? (Jared)
check out cometic gaskets. they were at SEMA...looked like some good stuff...cheap too...
Old Nov 4, 2001 | 06:34 PM
earl's Avatar
Default Re: Head gasket for turbo B18C????? (falconGSR)
Cometic is the only way to go. 800-752-9850 Pick your thickness and pick your bore size...
Old Nov 4, 2001 | 10:17 PM
type autox's Avatar
New User
has anyone stacked two stock headgaskets? I have heard of it being done, I just wonder if anyone has actually run this setup for an extended period of time.
Old Nov 7, 2001 | 01:32 PM
01-0338R's Avatar
Default Re: Head gasket for turbo B18C????? (type autox)
Thanks for the input
Old Nov 7, 2001 | 08:52 PM
ekb18c's Avatar
stock is fine.. we use a stock gasket on our 9 sec race car.
Old Nov 8, 2001 | 12:19 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Head gasket for turbo B18C????? (ekb18c)
After seeing the price of cometic, I cant believe how much Inline pro charges. $200 is pathetic. cometic was very helpfull and looks very good. Im gonna try them out to see how they work out, but I do prefer stock OEM.
art
Old Nov 8, 2001 | 12:23 AM
paulzy's Avatar
Default Re: Head gasket for turbo B18C????? (Arturbo)
how much are the cometic compared to the inlinepro or fmax gaskets? Are the copper or same metal at stock?
Old Nov 8, 2001 | 12:26 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Head gasket for turbo B18C????? (Slow_ass_4dr)
The cometic retails for about $80.
art
racerguy
Engine Machining & Assembly
Jan 12, 2019 09:38 PM
Muckman
Apr 6, 2018 11:25 AM
chasmataz
Jul 25, 2010 08:35 AM
Lmgrcivic
Feb 6, 2005 04:55 PM
u_tal
Oct 12, 2004 05:00 PM
