Wiseco 8.5:1 pistons (B18c1 turbo)
Old May 5, 2004 | 11:01 AM
elementmilwaukee
Guest
Posts: n/a
Default Wiseco 8.5:1 pistons (B18c1 turbo)
I just got a set of Wiseco 8.5:1 standard bore pistons delivered today and before I put them in I want to know.. If I upgrade the cams this winter, or redo the head and go with oversized valves will this pose a problem with these pistons? I couldn't get through to wiseco on the phone.... Thanks..
Dominic
Old May 5, 2004 | 03:45 PM
MrBui's Avatar
Default Re: Wiseco 8.5:1 pistons (elementmilwaukee)
it "shouldnt" be a problem
Old May 5, 2004 | 08:32 PM
patmcd's Avatar
Default Re: Wiseco 8.5:1 pistons (n20need4vtec)
Are you planning on running high boost or whats your reason for low comp pistons?
Old May 5, 2004 | 10:01 PM
Slain's Avatar
imagine he is going turbo soon by his signature
Old May 5, 2004 | 10:14 PM
Sack Master's Avatar
Default Re: (Slain)
I'm about 99.9% sure you'll be OK. If you have any doubts you can always clay the head. Thats the only way you'll know for sure if you are OK with piston to valve clearance.
reactone
Mar 20, 2009 12:27 PM
h22_crx
Apr 29, 2006 03:54 AM
masteryoda10
Jan 30, 2006 04:30 AM
turbochargeb18c
May 21, 2005 06:09 AM
