Props/Con on this set up
Old Nov 4, 2001 | 01:48 AM
SiBirdie's Avatar
Default Props/Con on this set up
This is on a B16a2
CTR piston
ITR CAMS
SKUNK 2 cam gear
Bais bolt on I/H/E
B&M Fuel reg.
vafc
will that yilled 175whp ? if not what to expect. thanx
Old Nov 4, 2001 | 03:16 AM
RagingAngel's Avatar
Default Re: Props/Con on this set up (SiBirdie)
sounds pretty much like Roger Foo's Civic setup.
Get a hondata....a lot of dyno time and depending on how good or bad your I/H/E combo is....you'll see the target figure...
but then again...peeps are waaaaaaaay too focused on peak whp huh?
Old Nov 4, 2001 | 05:02 AM
citanest's Avatar
New User
I dont' think so. Go to Godspeed's homepage and check out the Civic, see what it takes to get to around 175whp.
brad 1.cam
Jan 26, 2005 11:27 PM
NeOh 2ning
Aug 11, 2004 10:54 AM
tbud454
39
Apr 20, 2004 05:14 PM
del sol germany
Oct 23, 2003 02:13 PM
spoonda6
Feb 19, 2003 04:31 AM
