heater core removal/heater hoses
Old May 5, 2004 | 09:06 AM
spaceman's Avatar
Default heater core removal/heater hoses
im posting in here cuz i think maybe some of you have done this..i have crx/b16 and i removed the entire a/c and heater systems...my question is what did you guys do with your heater hoses,how did you re-route them and could you just cap them off?any pics?
Old May 5, 2004 | 09:56 AM
Boostin'RPS13's Avatar
Default Re: heater core removal/heater hoses (spaceman)
Maybe you should try the Tech Forum.
Old May 5, 2004 | 09:58 AM
99blackcivicSi's Avatar
Default Re: heater core removal/heater hoses (Boostin'RPS13)
you can either cap them off or loop them to each other either way would be fine.
Old May 5, 2004 | 01:18 PM
spaceman's Avatar
Default Re: heater core removal/heater hoses (99blackcivicSi)
if i cap them would that be ok for coolant/water circulation?..anyone have pics of how they did this..i wanna make sure im capping the right places
Old May 5, 2004 | 02:26 PM
jsdxhatch's Avatar
take the hose that normally goes IN to the heater core, unplug it from the core, then find the hose that exits the core and unplug that hose from the core and the engine....now take that first hose, and instead of it connecting to the core, connect it to the engine at the point where the second hose connected to the engine
hope this helps
Old May 5, 2004 | 06:06 PM
TurboJesse
Guest
Posts: n/a
Default Re: heater core removal/heater hoses (jsdxhatch)
i looped mine
Old May 5, 2004 | 09:24 PM
myhatchrips's Avatar
Default Re: heater core removal/heater hoses (Mpir3)
same here
Old May 6, 2004 | 06:39 AM
spaceman's Avatar
thanks for the info....now i need to find some good hose that is flexible so i can make the loop fit in my limited spaced engine bay..anyone know of any web sites with hose that i can use or where did you guys get your hose?
h4x
Sep 11, 2012 05:08 PM
stakskits
Feb 21, 2010 02:11 PM
hks_Racing
Dec 1, 2006 02:50 PM
coot_er
May 14, 2004 01:52 PM
