Dyno'd the ITR Swap.....
Old May 5, 2004 | 07:29 AM
chad's Avatar
Moderator
Default Dyno'd the ITR Swap.....
2000 STOCK ENGINE with toda header, AEM short ram, BC SpecIII exhaust, vafc and chipped p28
190 at 8450
132 tq from 5200 to 8000
Modified by chad at 2:14 PM 5/5/2004
Old May 5, 2004 | 07:30 AM
00MRSi's Avatar
Default Re: Dyno'd the ITR Swap..... (chad)
Nice.. Is this Kendall's old motor?
Old May 5, 2004 | 07:35 AM
ZygSpeed's Avatar
Looking good Chad!
Anyone have a spare VAFC?
Old May 5, 2004 | 07:50 AM
RTW DC2R's Avatar
strong motor
tuned stock cams?
Old May 5, 2004 | 07:53 AM
Philly_NBP_R's Avatar
Default Re: (RTW DC2)
wow.
I need to get a fuggn header damnit.
Old May 5, 2004 | 08:05 AM
00MRSi's Avatar
Default Re: (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">wow.
I need to get a fuggn header damnit.</TD></TR></TABLE>
You need a toda header..
Old May 5, 2004 | 08:17 AM
Tweakmeister's Avatar
ever consider running Uberdata w/ datalogging Wideband 02 and street tuning?
Old May 5, 2004 | 08:22 AM
Jon D's Avatar
mAN......i need to get me a header .
Edit: a toda header .
Old May 5, 2004 | 08:28 AM
Dr. EKology's Avatar
Not bad What type of dyno was this on?
Old May 5, 2004 | 09:05 AM
AamirCWITR's Avatar
Default Re: Dyno'd the ITR Swap..... (EKology)
that must be the strongest ITR engine with bolt ons i have ever seen,,,dont most stock ITR dynos drop off after 8000 rpms?
Old May 5, 2004 | 09:24 AM
Mugen Mike's Avatar
Damn good numbers
What's the mileage on the motoR?
Old May 5, 2004 | 09:26 AM
jorge's Avatar
great numbers for slightly modded engine
Old May 5, 2004 | 09:29 AM
Travis.EK's Avatar
Looking good.
Old May 5, 2004 | 11:50 AM
chad's Avatar
Moderator
Default Re: Dyno'd the ITR Swap..... (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">strong motor
tuned stock cams?</TD></TR></TABLE>
STOCK UNTOUCHED ENGINE!!! cept for header, intake.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">ever consider running Uberdata w/ datalogging Wideband 02 and street tuning?</TD></TR></TABLE>
no....but tell me more....i have a wideband avail to me for use....never hooked it up....knew i'd dyno it soon....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology &raquo;</TD></TR><TR><TD CLASS="quote">Not bad What type of dyno was this on?</TD></TR></TABLE>
dynojet....just for comparison sake another ITR SWAP with only stock header put down 180 and 126
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR &raquo;</TD></TR><TR><TD CLASS="quote">that must be the strongest ITR engine with bolt ons i have ever seen,,,dont most stock ITR dynos drop off after 8000 rpms?
true....i have not seen another ITR pull past 8500 with stock engine.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge &raquo;</TD></TR><TR><TD CLASS="quote">great numbers for slightly modded engine </TD></TR></TABLE>
ENGINE IS NOT MOD'D at all!!! only bolt ons....
Old May 5, 2004 | 11:53 AM
BlueR's Avatar
chad, my POS better be pulling some of those #s too
Old May 5, 2004 | 11:58 AM
kitkatR's Avatar
Default Re: Dyno'd the ITR Swap..... (BlueR)
damn I have JUN 3's and only pulled 190 (stock injectors and compression). I am jealous
On a side note Chad you wont be able to rag my car around the track at this expo cause it wont be there
Old May 5, 2004 | 12:00 PM
RinBlue's Avatar
those number sound like ****. and a lie. or maybe that dyno you're running on is WRONG. I never seen a stock ITR motor put down 190 to the wheels with those simple bolt ons and NO CAMS.. seems shady check that dyno.
Old May 5, 2004 | 12:19 PM
all stock's Avatar
Default Re: Dyno'd the ITR Swap..... (RinBlue)
header and vafc net him 10whp over me , i don't think that's a lie. good numbers
Old May 5, 2004 | 12:22 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Dyno'd the ITR Swap..... (all stock)
DAMN talk about a strong motor! I this motor still in a hatch Chad?
Old May 5, 2004 | 12:23 PM
G
sh!t happens.
Old May 5, 2004 | 12:24 PM
RTW DC2R's Avatar
having a hard time believing this. post the charts y0
Old May 5, 2004 | 12:25 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">2000 STOCK ENGINE with toda header, AEM short ram, BC SpecIII exhaust, vafc and chipped p28
190 at 8700
134 tq from 5200 to 8000
good to see.. hopefully mine ends up right around there..
who chipped the ECU? how much tuning did you have to do with the vafc? tetpipe, or highflow cat?
Old May 5, 2004 | 12:30 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">no....but tell me more....i have a wideband avail to me for use....never hooked it up....knew i'd dyno it soon....</TD></TR></TABLE>
Uberdata is simply a free hondata. But it is strictly DIY. I'm using this as soon as i finish my ITB project. I already have all the hardware etc etc. Basically you download the program, buy the appropriate hardware (batronix burner, chips, resistors etc...) and road tune using a wideband and datalogging software and make changes, burn chips, make another run, repeat 1000x until you're perfect. Then dyno tune the cam gears and ignition timing. Its a laptop based softare VERY similar in design to the original hondata, if you've ever seen/used it.
Old May 5, 2004 | 12:33 PM
igyloo's Avatar
Default Re: Dyno'd the ITR Swap..... (AamirCWITR)
toda header
Old May 5, 2004 | 12:48 PM
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RinBlue &raquo;</TD></TR><TR><TD CLASS="quote">those number sound like ****. and a lie. or maybe that dyno you're running on is WRONG. I never seen a stock ITR motor put down 190 to the wheels with those simple bolt ons and NO CAMS.. seems shady check that dyno.</TD></TR></TABLE>
first off how do numbers sound like chit??? second off...why would chad lie about this? im sure hes lieing about this thread just like that thread where he pulled on a sc'ed gt...and i know for sure this motor puts down those numbers because i have a itr swap in my hatch (same setup in his and my hatch...same engines except the h/e/tuning are different on his) and he pulled on me like whoa!!!
