Can someone identify these calipers for me?
Old May 5, 2004 | 05:25 AM
pbomers's Avatar
Default Can someone Identify these ITR Calipers for me?
I bought these JDM ITR calipers, but am wondering if they are GSR calipers instead. I need to order pads in the next couple days from cobalt and didn't want to order the wrong ones.
Are there any sure ways to tell if they are ITR calipers or not?
This is the only pic I've got.
Is the piston bigger on the ITR or anything that I could measure? My friends GSR calipers are 48mm ID on the piston and his GSR pads fit in side to side, but seem kinda small height wise.
Thanks for any info guys, sorry about the long post.
-Paul
Old May 5, 2004 | 06:41 AM
Dan GSR's Avatar
Default Re: Can someone Identify these ITR Calipers for me? (TinyCRX)
did u get the calipers from brian at fast brakes? if so, and he says they are ITR, no reason to not belive him
Old May 5, 2004 | 07:20 AM
Chris93Si's Avatar
Default Re: Can someone Identify these ITR Calipers for me? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">did u get the calipers from brian at fast brakes? if so, and he says they are ITR, no reason to not belive him</TD></TR></TABLE>
Exactly what I was gonna say, if you got them from Brian no doubt they are ITR
Old May 5, 2004 | 07:21 AM
pbomers's Avatar
I actually got them used from someone in Canada.
Old May 5, 2004 | 07:46 AM
KOALA YUMMIES's Avatar
Go to the dealership and test fit the pads.
Old May 5, 2004 | 07:58 AM
hypa's Avatar
If they need a bracket to mount to your GSR arms, then they're ITR. The pistons are the same diameter between the GSR and ITR calipers, it's the chassis and pad mount that are larger, to take on the larger ITR rotor.
This was tested and proven by me a few months ago with ITR and GSR calipers in hand.
Old May 5, 2004 | 08:12 AM
an2ny888's Avatar
Default Re: (hypa)
it should say 17 CL15VN on it
Old May 9, 2004 | 03:15 PM
pbomers's Avatar
Default Re: (an2ny888)
They actually say CL14VN.
Old May 9, 2004 | 04:34 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">If they need a bracket to mount to your GSR arms, then they're ITR. The pistons are the same diameter between the GSR and ITR calipers, it's the chassis and pad mount that are larger, to take on the larger ITR rotor.
Honda Type R
Suspension & Brakes
Jun 20, 2015 01:20 PM
1_slow_crx
Dec 21, 2006 02:14 PM
Garrett
May 3, 2004 09:29 AM
Rob Dizzle
Dec 8, 2003 06:48 AM
gsr98vtec
Jun 5, 2002 11:33 AM
