I can't find my wheel lock...
Old May 4, 2004 | 11:47 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default I can't find my wheel lock...
Is there a way of taking off the lock without messing up the rims?
Old May 5, 2004 | 08:02 AM
timmy8151's Avatar
Default Re: I can't find my wheel lock... (GapxGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way of taking off the lock without messing up the rims?</TD></TR></TABLE>
Are the wheel lock OEM McGards? If they are, then you can try to contact McGard or Acura and get another key. However, you're going to need the serial # of your locks. If you have the original packaging, its on the back.
The only other option is to have it taken off using an airgun.
Old May 5, 2004 | 08:20 AM
mrmonk's Avatar
Default Re: I can't find my wheel lock... (timmy8151)
it will cause some damage if you us an air gun
Old May 5, 2004 | 10:08 AM
APEX CRX's Avatar
Default Re: I can't find my wheel lock... (mrmonk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">it will cause some damage if you us an air gun</TD></TR></TABLE>
no, it'll only damage the wheel lock. most people try to hammer on a socket onto the wheel lock. you sometimes get lucky and get them off and still not damage the lock. OR go to a tire shop and have them do it. Snap-on and other tool makers have special kits.
Old May 5, 2004 | 06:06 PM
GapxGuy's Avatar
Default Re: I can't find my wheel lock... (APEX CRX)
It's an aftermarket wheel lock. I could care less if it damages the lock itself, I just don't want it to damage the rims. So how does using the airgun and socket method work?
Old May 5, 2004 | 06:21 PM
cmrvi1's Avatar
Go to one of the autoparts stores and ask for a wheel lock removal socket.
It tightens over the wheel lock in reverse and loosens it. You might be able to remove it with a breaker bar, but it's really made to be used with an impact gun.
BTW, they're only around 15 bucks.
StolenTeg
Nov 22, 2007 09:34 AM
GoldCoin
Mar 1, 2007 02:29 PM
1Quikgsr
30
Nov 10, 2006 09:28 PM
Crono139
Jan 28, 2004 12:03 PM
MarkZeroNine
11
Oct 20, 2003 08:32 AM
