Questin about Hondabond and oil pans...
I just changed my oil pan and it has a slight drip/leak. At the time I didn't have any Hondabond or anything so I didn't use any. I'm going to drop my pan again tomorrow to fix it, and I know Helms says to put Hondabond on the corners but would it be ok if i put a thin layer of it all around and on both sides? Would this help with sealing?
and is there more than one type of Hondabond? I have the kinda in a black, white, and red tube.
My helms says to use it at the joint where the oil pump and block meet, and at the same spot on the passenger side. I just thought that using it all around might give me a better shot at having no leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS »</TD></TR><TR><TD CLASS="quote">My helms says to use it at the joint where the oil pump and block meet, and at the same spot on the passenger side. I just thought that using it all around might give me a better shot at having no leaks.</TD></TR></TABLE>
I find it best not to deviate from the ali-knowing Helms.
The helms manual does state to use it on the four corners. As long as you clean the pan and block surface with some carb cleaner, apply the sealant where recommended it shouldn't leak, If you decide to put the hondabond all the way around make sure it is dry before sticking the pan on because when you start to tighten, the wet hondabond will make the gasket slip around and make your problem worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">Where do you get hondabond, is this made by honda?</TD></TR></TABLE>
Actual Hondabond is bought at Honda dealerships for a ridiculous price.
Despite what others will say, RTV Ultra Grey Sealant from the local Autozone is the exact same junk, and less than half the price.
