Gsr Injectors and fuel rail on an LS motor?
Old May 4, 2004 | 05:28 PM
Pythagoras's Avatar
Default Gsr Injectors and fuel rail on an LS motor?
Like the topic says, will GSR injectors and a GSR fuel rail fit onto an B18 LS engine?
Are there any downfalls to doing this over just replacing ithem with new ls parts.
Old May 4, 2004 | 07:21 PM
zilverz's Avatar
Default Re: Gsr Injectors and fuel rail on an LS motor? (2000ebp_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000ebp_si &raquo;</TD></TR><TR><TD CLASS="quote">Like the topic says, will GSR injectors and a GSR fuel rail fit onto an B18 LS engine?
Are there any downfalls to doing this over just replacing ithem with new ls parts. </TD></TR></TABLE>
not sure about the fuel rail ... if the mount bolts line up the same or not . but the injectors are the same 240cc
Old May 4, 2004 | 08:02 PM
Audi A4's Avatar
Default Re: Gsr Injectors and fuel rail on an LS motor? (zilverz)
since the mani is diff the fuel might mount diff... ud would have to see how it mounts... if it mounts the same u can use it but its gonna flow the same as ls
Old May 5, 2004 | 10:24 AM
Pythagoras's Avatar
Someone has to know about the fuel rail.......
Old May 5, 2004 | 12:44 PM
mskibbz-T's Avatar
There are no advantages to switchin to a GSR fuel rail...
Old May 5, 2004 | 06:54 PM
zilverz's Avatar
just used common sense on the fuel rail.
went to a website ... the AEM fuel rail is the same rail for for integras 94-01 any model... so the bolt holes must line up.
Old May 5, 2004 | 07:02 PM
Pythagoras's Avatar
Thanks.....I know there really is no advantage but my friend got injectors and a fuel rail from a gsr for really cheap so he just wanted me to find out if they fit an ls.....
slo_ej8
Mar 27, 2008 10:15 AM
99blackLS
Feb 8, 2006 06:41 PM
Greasemonkey
Apr 13, 2004 01:24 PM
BI8B
Jan 12, 2004 08:29 AM
b20guy
Aug 15, 2002 10:57 PM
